Calculate Molarities of HCl & NaOH Solutions: Titration Ques
  • Thread starter Thread starter tipton12
    Titration
The discussion focuses on calculating the molarities of hydrochloric acid (HCl) and sodium hydroxide (NaOH) solutions using a primary standard grade sodium carbonate (Na2CO3). A 0.4793g sample of Na2CO3 was reacted with 40.00mL of dilute HCl, followed by back-titration with 8.70mL of NaOH. The molarity calculations involve determining the moles of Na2CO3 and using the neutralization reaction data, specifically that 27.43mL of HCl neutralized 25.00mL of NaOH. Key insights include recognizing that the purity of the primary standard is considered 100% and understanding the relationship between molarity, volume, and moles.
  • Understanding of titration techniques
  • Knowledge of molarity calculations
  • Familiarity with stoichiometry in chemical reactions
  • Basic concepts of acid-base neutralization reactions
  • Calculate the moles of Na2CO3 using its molar mass
  • Determine the moles of HCl used in the reaction
  • Calculate the molarity of the NaOH solution based on the neutralization data
  • Review acid-base titration principles and calculations
Chemistry students, laboratory technicians, and educators involved in teaching titration methods and molarity calculations.
tipton12
A 0.4793g sample of primary standard grade Na2CO3 was treated with 40.00mL of dilute HCl. The solution was boiled to remove CO2 and then excess HCl was back-titrated with 8.70mL of NaOH. In a separate experiment, it was established that 27.43mL of the HCl neutralized the hydroxide in a 25.00mL portion of the NaOH solution. Calculate the molarities of the HCl and the NaOH solutions.
I need a starting point or steps. I was thinking about finding the number of moles of the standard Na2CO3 present. But other than that, I'm a little overwhelmed with what to do with all the volumes given. Please help on the homework problem!
Chemistry news on Phys.org
Hello, I see that a lot of people encounter some difficulty in understanding these.
Please remember that molarity has the dimension of [tex]\frac{mol}{L}[/tex] or [tex]\frac{mmol}{mL}[/tex], while multiplying this with volume gives mol or mmol, respectively.
You can try writing the reaction formula to see how many mols of reactants are required for a complete reaction, and you can find how many moles of HCl are in excess.
A last hint: if someone says that there is a primary standard, you can understand that its purity can be considered as 100%.
17K
22K
9K
10K
17K
16K
