Register to reply
Finding the magnitude of an electric field at a distance from a surface charge
by NewtonianAlch
Tags: charge, distance, electric, field, magnitude, surface
Share this thread:
NewtonianAlch
#1
Aug3-11, 03:49 AM
P: 440
Find the magnitude of the electric field intensity at a distance 0.15m from the axis of a long, straight conductor, which has radius 0.03m, and a charge density of 4.0 C/m.
2. Relevant equations
Eflux = E.A
Eflux = q/e0
q = sigma*h
3. The attempt at a solution
Eflux = E*Area
Thus, Eflux = E*2pi*r*h (Surface area of the gaussian cylinder we superimpose over the conductor)
Also, Eflux = q/e0 -> where e0 is the permittivity of free space and q is the enclosed charge in the gaussian surface.
q = sigma*h
Therefore we substitute for the q, and equate the two Eflux equations to get:
Eflux = E*2pi*r*h = sigma*h/e0
Solve for E and we get:
E = sigma/(2pi*r*e0)
Now we substitute the given values:
4/(2pi*(0.03)*(8.85*10^-12)) = 2.40*E12 or 2.40*10^12 N/C
I have no idea how to find the electric field at the distance 0.15m away from the surface. Please help! I would need the value of q to do this, however this is not a point charge we're dealing with but a surface charge, so I'm a bit lost.
Phys.Org News Partner Science news on Phys.org
Guidelines for enhancing solar cells using surface plasmon polaritons
Trees and shrubs invading critical grasslands, diminish cattle production
Climate change will threaten fish by drying out Southwest US streams, research predicts
Mike Pemulis
#2
Aug3-11, 04:10 AM
P: 120
If you look back over your logic, you should see that the r you plug in to the final formula is not the radius of the charged cylinder, it's the radius of the Gaussian surface, which is 0.15m. The radius of the cylinder is actually irrelevant.
NewtonianAlch
#3
Aug3-11, 04:14 AM
P: 440
Quote Quote by Mike Pemulis View Post
Wow...I can't believe I didn't notice that inflating the imaginary Gaussian surface would give the required 'r' of 0.15m.
Though...why would they give the radius of the cylinder if it had no part in it?
Mike Pemulis
#4
Aug3-11, 04:18 AM
P: 120
To see if you would make this mistake. One note: as long as the Gaussian cylinder is outside the wire, the radius of the wire doesn't matter. But another common problem you may encounter is to find the E field inside the wire some distance from the center -- then, the radius of the wire matters.
Jaynte
#5
Aug3-11, 04:19 AM
P: 71
Teachers do that alot. It's to confuse you and see that you really understand the problem.
NewtonianAlch
#6
Aug3-11, 04:20 AM
P: 440
Hmm yea, I've noticed that kind of question appears to be common with coaxial wires.
Thank you for your help!
Register to reply
Related Discussions
The magnitude of the electric field a perpendicular distance from the midpoint of the Introductory Physics Homework 1
Magnitude of electric field outside surface of sphere Introductory Physics Homework 0
Magnitude of electric field due to line of charge Introductory Physics Homework 3
Finding magnitude of surface charge density. Introductory Physics Homework 1
Magnitude of charge on oil drop (electric field) Introductory Physics Homework 11
