Determine the general solution of QL PDE
The discussion revolves around determining the general solution of a partial differential equation (PDE) given by the equation \( u u_x - y u_y = y \). Participants are exploring methods of implicit differentiation to verify their solutions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to derive the general solution using a method involving separable variables and integration. They express uncertainty about the correctness of their solution and seek clarification on the verification process through implicit differentiation.
Some participants are actively engaging with the original poster's attempts, while others have noted a separate forum post for additional input. The discussion includes questions about the integration process and the notation used in the solution.
There are indications of confusion regarding the notation and the function involved in the solution. The original poster has acknowledged a missing function symbol in their attempt, which may affect the clarity of their solution.
bugatti79
1) Determine the general solution of the equation
2) Use implict differentiation to verify that your solution satisfies the given PDE
[tex]u u_x-y u_y=y[/tex]
[tex]\frac{dx}{u}=\frac{dy}{-y}=\frac{du}{y}[/tex]
Take the second two
[tex]\int-dy=\int du \implies u=-y+A[/tex]
Taking the first two
[tex]\frac{dx}{(-y+A)}=\frac{dy}{-y} \implies dx=\frac{(-y+A)dy}{-y}[/tex]
Integrating gives
[tex]x=y-A \ln(y) + f(A)[/tex] but [tex]f(A)=u+y[/tex] therefore the general solution implicitly is
[tex]x=y-A \ln(y) + u+y[/tex]
1) How am I doing?
2) I don't know how to do second question assuming above is correct
3) How do I create the tags automatically?
Thanks
Folks,
I have also posted this query at
http://www.mathhelpforum.com/math-help/f59/determine-general-solution-ql-pde-185703.html"
I will keep each forum informed. No luck yet.
Thanks
Take the second two
Integrating gives
[tex]x=y-A \ln(y) + f(u+y)[/tex]
1) How am I doing?
Thanks
I realized I left out the function f symbol as highlighted above. Any ideas?
This is solved...See link in post 2
Cheers
