Friction problem Does this make sense?
  • Thread starter Thread starter armolinasf
    Friction
The discussion centers on determining the maximum amplitude of oscillation for a system of two stacked masses, M and m, where M is attached to a spring with a force constant k. The coefficient of static friction between the masses is denoted as w. The correct formula for maximum amplitude x is derived as x = (w(m + M)g) / k, which accounts for the total mass being accelerated and the frictional force preventing slipping. The reasoning provided confirms that the acceleration of the top mass must match the acceleration of the bottom mass at maximum oscillation.
  • Understanding of Newton's laws of motion
  • Familiarity with spring mechanics and Hooke's Law
  • Knowledge of static friction and its coefficient
  • Basic concepts of oscillatory motion and amplitude
  • Study the derivation of Hooke's Law and its applications in oscillatory systems
  • Explore the dynamics of friction in multi-body systems
  • Learn about the effects of mass distribution on oscillation amplitude
  • Investigate the role of acceleration in preventing slipping in stacked masses
Students and educators in physics, mechanical engineers, and anyone studying dynamics and oscillatory motion in multi-body systems.
armolinasf
There are two masses stacked on top of each other. The bottom one, M, is attached to a spring with force constant k. The coefficient of static friction between the M and the top mass, m, is w. What is the maximum amplitude of oscillation such that the top box will not slip on the bottom.
Initially my reasoning was that the force of friction, wn, where n is the normal force acting on the top box equal to mg, must equal the pulling force, f=kx
wmg=kx then x=(wmg)/k. The answer in my book gives x= (w(m+M)g)/k
I'm not sure if the way I arrived at that answer is correct:
F=kx=(m+M)a ==> a1=kx/(m+M)
wmg=kx ==>wg=kx/m=a2
But a2 is really equal to a1 since that's the box that's what's being accelerated.
wg=kx/(m+M) ==>w(m+M)g/k = x
I just want to be sure that makes sense. Thanks for the help
Looks ok to me. You need the mass on the top not to slip at the point of maximum acceleration, which is when x is at its maximum value of oscillation.
  • · Replies 18 ·
