Torsion Shear of Shaft with Transverse Hole
The discussion focuses on calculating the allowable shear stress (tau) for a shaft with two transverse pin holes. The formula used is tau = Tc / J, where Tc is the torque multiplied by the distance from the center of gravity to the extreme fiber, and J is the polar moment of inertia. The calculation for J includes the polar moment of a solid circle and subtracts the polar moment due to the pin holes. The correct expression for J is J = (pi*D^4)/32 - (d*D(d^2 + D^2))/12, confirming the validity of the equation.
  • Understanding of shear stress and torque concepts
  • Familiarity with polar moment of inertia calculations
  • Knowledge of basic mechanics of materials
  • Ability to manipulate algebraic equations
  • Study the derivation of polar moment of inertia for various shapes
  • Learn about shear stress distribution in shafts with holes
  • Explore advanced mechanics of materials textbooks for in-depth examples
  • Research the effects of different hole configurations on shaft strength
Mechanical engineers, materials scientists, and students studying mechanics of materials who are involved in the design and analysis of shafts and rotating machinery.
jmart157
Looking to figure out the allowable stress (psi) of a shaft which has two pin holes in it on the transverse axis of the shaft.
tau = allowable stress, psi
T = torque, in-lb
c = distance from center of gravity to extreme fiber
J = polar moment of inertia
D = diameter of the shaft
d = diameter of the pin hole
tau = Tc / J = (T*(D/2)) / (((pi*D^4)/32) - (d*D(d^2 + D^2))/12)
I think this is right. but i don't know why it is right. Can someone please help me prove the backend of the equation? ie: (d*D(d^2 + D^2))/12)
jmart157: I am not yet an expert but whould give some input.
The tau = Tc / J equation is indeed correct
Tc = T*(D/2), which I think you understand
So the J = (((pi*D^4)/32) - (d*D(d^2 + D^2))/12) part I think is where you are struggling...
When looking at the shaft: Jcircle = (pi*D^4)/32) which is the first part
and the hole the pin creates has a square cross sectional area:
Jsquare = (d*D(d^2 + D^2))/12
So the total polar moment of the cross sectional area: Jtotal=Jcircle-Jsquare
Hope this helps, check the attackment that I've put together to help you
10K
17K
