Help on precise definition of chemical potential T->0 FD Distribution
The discussion revolves around the definition and implications of chemical potential in the context of the Fermi-Dirac distribution, particularly as the temperature approaches zero. Participants explore the relationship between chemical potential and Fermi energy, questioning how the addition of particles affects these concepts.
  • One participant defines chemical potential as the change in energy associated with adding a particle to a closed system of N particles, linking it to the Fermi energy at T -> 0.
  • The same participant expresses confusion about why adding a particle would equate to the Fermi energy if that state is already occupied, suggesting that the new particle would occupy a state above the Fermi energy.
  • Another participant emphasizes that the issue is statistical in nature, indicating that the question is more complex than a straightforward arithmetic problem.
  • A later reply suggests that the discussion of chemical potential pertains specifically to metals rather than insulators, hinting at different behaviors in these materials.
Participants do not appear to reach a consensus, as there are differing interpretations of the relationship between chemical potential and Fermi energy, and the implications of adding particles to the system remain contested.
The discussion highlights potential limitations in understanding the statistical nature of chemical potential and its dependence on the type of material (metal vs. insulator), as well as the assumptions made regarding particle occupancy at low temperatures.
pam d
Hello everyone, first post here.
In trying to decipher the meaning of chemical potential, I feel as if at least in the context of the Fermi-Dirac Distribution I have almost nailed it down. As I understand it, the chemical potential is the change in energy associated with the addition of one particle to an otherwise closed system of N particles. Looking at a system of particles obeying Fermi-Dirac statistics as the temperature becomes arbitrarily close to zero, I have read several times that the chemical potential is given by the Fermi energy.
Now I think I understand the Fermi energy, it is just the highest energy occupied by a fermion as T -> 0. Assuming no degeneracy, I am confused as to why the addition of one particle would add energy equal to the Fermi energy. If this state is already occupied, wouldn't the particle be forced to occupy the one state with energy above the Fermi energy? Would this not force the chemical potential for N particles to then be the Fermi energy of N+1 particles rather than that of N particles?
I often find in physics problems that when I become stuck on an issue like this one, I am making a fundamental error that requires outside guidance.
Thanks!
It is just a statistical problem, not just a 1+1=2 problem.
Understood perb, which means I guess I'm not looking for a 1+1=2 response! Seems like you might have some kind of knowledge on the subject though, so I'll bite. I'll put away my arithmetic tables, but what next?
I mention 1+1=2 doesn't mean that your question is a simple question.
I think that the chemical potential mentioned here is referred to metal, not insulator.
18K
