What Is the Correct Calculation for the Mass of the Sun?
  • Thread starter Thread starter SpeedBird
    Mass Sun The sun
The discussion revolves around calculating the mass of the Sun using the Earth's orbital parameters, specifically assuming a circular orbit with a radius of 1.5 * 10^8 km. The original poster expresses confusion regarding their calculated result compared to expected values.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply Kepler's Law to derive the mass of the Sun, noting their calculations for the orbital period and radius. They question the validity of their result, suspecting an error in their approach or assumptions.
Participants are engaging in clarifying the formula used and discussing the correctness of the original poster's calculations. Some guidance has been offered regarding the formula, and there is a recognition of a potential misunderstanding about the expected mass value.
There is a discrepancy between the calculated mass and the expected mass of the Sun, with some participants suggesting that the original poster may have misinterpreted the expected answer. The discussion also touches on the reliability of external sources for values.
SpeedBird
hey there, i am having trouble with what should be a really easy question!
calculate the mass of the sun assuming that the Earth's orbit is circular
and with a radius of 1.5 * 10^8 km
i got the period of the Earth's orbit around the sun in seconds:
60*60*24*365.25
then used the formula:
T = ((4*Pi^2*r^3)/(G*M))^2
rearranging in terms of M
i change the radius of the orbit to metres instead of kilometres before putting
it into the formula.
but the answer i get is 1.9 * 10^30 kg
and i think the answer should be in the order of 10^40 kg
can anyone suggest where i might be going wrong?
thanks
Nik
This is Kepler's Law
[tex]T^2 = \frac{4 \pi^2}{GM} r^3[/tex]
rearranged into
[tex]M = \frac{4 \pi^2}{GT^2} r^3[/tex]
now sub in and see what s wrong
i see i wrote the formula wrong in my original post!
i meant raised to the power of 1/2 at the very end.
i am still getting 2 * 10^30 as my answer..
this might be the correct answer and the question is just
unrealistic?
Nik
the question is not unrealistic, the mass of the sun is 1.99x10^30 kg the answer of the book of 10^40 is wrong (or you're looking at the wrong question)
ahh thank you! i found the value from a search on google :-S
it didnt even cross my mind that the value was wrong.
thank you very much!
Nik
  • · Replies 21 ·
