New Reply
An object on an inclined plane
Share Thread Thread Tools
Aug10-11, 07:04 AM   #1
A homogenous thin cylinder is put on an inclined plane (angle of elevation is α). The coefficient of friction is [tex] \mu [/tex] . What is the speed of the centre of the mass of the cylinder and it's angular velocity at distance l from the start of motion.
2. Relevant equations
[tex] F=ma [/tex]
[tex] I=mR^2/2 [/tex]
[tex] v=at [/tex]
3. The attempt at a solution
I drew a free body diagram and found out that the acceleration is
[tex] a=g(sinα-\mu\cosα) [/tex] and found the velocity
[tex] v=\sqrt{2lg(sinα-\mu\cosα)} [/tex]
The problem is, i can't find the angular velocity in any way.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Aug10-11, 07:12 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
I presume this is pure "rolling", no sliding, motion. In one complete rotation, then, the cylinder will have moved a distance equal to the circumference of the cylinder. Since you know the linear speed of the center axis, you know the time it will take the cylinder to move that far. The angular speed is [itex]2\pi[/itex] radians divide by that time.
Aug10-11, 07:12 AM   #3
Mentor
Quote by funoras View Post
How did you derive this result?
Same question here.
The translational and rotational velocities are related by the constraint that the cylinder rolls without slipping.
Aug10-11, 08:22 AM   #4
[tex]N=mgcos\alpha[/tex]
[tex]ma=mgsin\alpha-F[/tex]
[tex]F=\mu N[/tex]
and from here
[tex]a=g(sinα−μcosα)[/tex]
and the distance l is
[tex]l=at^2/2[/tex]
from here [tex]t=\sqrt{2l/a}[/tex]
and velocity is [tex]v=at=\sqrt{2lg(sinα−μcosα)}[/tex]
But that would mean the cylinder is sliding i guess. I'm completely lost now.
Aug10-11, 08:41 AM   #5
Mentor
[tex]F=\mu N[/tex]
Do not assume this. F = μN would be the maximum possible value of static friction for the given surface; the actual friction needed to prevent slipping will be less. Just call the friction F and solve for it.
(Don't forget Newton's 2nd law for rotation.)
Aug10-11, 08:56 AM   #6
So
[tex] mg sin \alpha - F = ma [/tex]
[tex] FR=mR^2\beta/2 [/tex]
[tex]a=\beta R[/tex]
and from here [tex]a=2gsin\alpha /3[/tex]
and i can find the translational velocity, but what about the angular velocity? it seems i will need the radius, which is not given
Aug10-11, 09:07 AM   #7
Mentor
Yes, you are correct. It seems you do not have enough information to obtain the angular velocity.
(If this is a textbook problem, what book is it from?)
Aug10-11, 09:31 AM   #8
It's not a textbook problem. However, thanks a lot for your help ! :)
New Reply
Thread Tools
Similar Threads for: An object on an inclined plane
Thread Forum Replies
Object Rolling Down Inclined Plane Introductory Physics Homework 1
Inclined Plane-Acceleration of Object Introductory Physics Homework 1
Object going up inclined plane with friction, how far does it go? Introductory Physics Homework 1
Motion of 2 object on an inclined plane Introductory Physics Homework 1
Object being pushed up an inclined plane Introductory Physics Homework 4
