Find Local Approximation of f(x)=x^(1/3) at x=26.6 with f(27)=3
The problem involves finding the local approximation of the function f(x) = x^(1/3) at the point x = 26.6, given that f(27) = 3. Participants are exploring methods to derive this approximation without using a calculator.
  • Participants discuss the derivative of the function and the formula for linear approximation. There are attempts to substitute values into the approximation formula and questions about the validity of the results obtained. Some participants express uncertainty about their calculations and seek confirmation.
The discussion is ongoing, with participants sharing their calculations and reasoning. Some guidance has been offered regarding the formula for linear approximation, and there is a recognition that the results are close to the expected value. However, there is no explicit consensus on the correctness of the answers provided.
Participants mention constraints such as the requirement to solve the problem without a calculator, which influences their approach to the calculations.
UrbanXrisis
I need to find thelocal approximation of f(x)=x^(1/3) at x=26.6, knowing f(27)=3.
Here's what I did, don't know if I did it right:
f '(x)=(1/3)x^(-2/3)=[x^(-2/3)]/3
slope of the tanget = slope of the secant
[x^(-2/3)]/3=(y-y1)/(x-x1)
[26.6^(-2/3)]/3=(y-3)/(x-27)
now I sub in X and solve for y:
[26.6^(-2/3)]/3=(y-3)/(26.6-27)
y=2.985
I don't think that's the answer at all, could someone check it?
y=2.985
your answer is reasonable. why? it's just under the cube root of 27, which is what you're looking at. cube that number to check your results -- 26.597 pretty close.
as i recall
the formula is L(x) = f(a) + f'(a)(x-a)
f(x) = x^(1/3)
f'(x) = 1/(3x^(2/3))
i arrive at the same answer plugging those values in.
f(x) = x^(1/3)
However, I'm not supposed to use a calculator to solve it...is there an easier way?
well subsitute the values in fractional form
3 + 1/3(27)^2/3(26.6-27)
3+(1/27)(-4/10)
3-4/270 = 3-2/135 = 2.985
the fractional answer is correct, the decimal is simply an approximation of the fractional expressoin. (both are approximations, keep that in mind)
  • · Replies 17 ·
  • · Replies 17 ·
