Where Does Energy Go When Water Boils?
  • Thread starter Thread starter imboring2000
    Boiling Homework
When water boils, thermal energy is transferred from the heat source to the water, facilitating a phase change from liquid to gas through the process of evaporation, which is defined by the heat of vaporization. Energy is utilized to break the molecular bonds of water, allowing it to transition into vapor. Additionally, when using a hot plate, it consistently transfers energy to the water at a steady rate until the boiling point is reached.
  • Understanding of thermal energy and heat transfer
  • Knowledge of phase changes, specifically evaporation
  • Familiarity with the concept of heat of vaporization
  • Basic principles of thermodynamics
  • Research the concept of heat of vaporization in detail
  • Explore the principles of thermodynamics related to phase changes
  • Learn about energy transfer mechanisms in heating systems
  • Investigate the effects of pressure on boiling points and phase changes
Students studying thermodynamics, educators teaching physical science, and anyone interested in the principles of heat transfer and phase changes in water.
imboring2000
hi! I wanted to know the answer for this question: Where is the energy going when the water is boiling? We are talking about thermal energy in my class. Also, If I would place a beaker of water on a hot plate in order for it to get hot and change temperature, Would the hot plate transfer energy to the water at a steady rate?
Thanks
imboring2000 said:
Where is the energy going when the water is boiling? Thanks
When the water is boiling, the energy travles from the fire to the boiler, the boiler to the water, this causes the water to "boil" which means that it is undergoing a phase change (water to gas). The energy is used for evaporation (Heat of Vaporization). Some of the energy form the water is transferred to the air.
imboring2000 said:
Also, If I would place a beaker of water on a hot plate in order for it to get hot and change temperature, Would the hot plate transfer energy to the water at a steady rate? Thanks
Yeah, but the word "steady" is a little sketchy to me.
Hi there! When water is boiling, the energy is going into breaking the bonds between the water molecules, causing them to turn into vapor. This is known as the heat of vaporization and is a type of thermal energy. As for your second question, yes, the hot plate would transfer energy to the water at a steady rate. This is because the hot plate is constantly emitting heat, and the water will continue to absorb that heat until it reaches its boiling point. I hope this helps with your homework!
  • · Replies 18 ·
