What is the Distance Between Two Masses When a Spring is Fully Stretched?
  • Thread starter Thread starter cissablecat23
    Stuck
The distance between two masses, m1 = 9.04 kg and m2 = 7.31 kg, when a spring with a constant of k = 122 N/m is fully stretched for the first time is 0.220 m. This distance is calculated using the principles of Simple Harmonic Motion and the equations derived from Hooke's Law and the Law of Conservation of Energy. The angular frequency (ω) is determined to be 3.641 rad/s, and the time taken for m1 to reach full stretch is 0.428 seconds, at which point m2 has moved 0.257 m from the equilibrium position. The final calculation confirms that the two masses are 0.220 m apart at the moment the spring is fully stretched.
  • Understanding of Simple Harmonic Motion
  • Familiarity with Hooke's Law
  • Knowledge of Newton's 2nd Law
  • Concept of the Law of Conservation of Energy
  • Study the equations of motion for Simple Harmonic Motion
  • Learn about the applications of Hooke's Law in mechanical systems
  • Explore the relationship between potential energy and kinetic energy in oscillatory systems
  • Investigate the effects of mass and spring constant on oscillation frequency
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of oscillatory systems and energy conservation principles in mechanics.
cissablecat23
A mass, m1 = 9.04 kg, is in equilibrium while connected to a light spring of constant k = 122 N/m that is fastened to a wall
A second mass, m2 = 7.31 kg, is slowly pushed up against mass m1, compressing the spring by the amount A = 0.220 m The system is then released, and both masses start moving to the right on the frictionless surface. When m1 reaches the equilibrium point, m2 loses contact with m1 and moves to the right with speed v. Determine the value of v.
potential energy= kinetic energy
0.5kA^2=0.5mv^2
v= sqrt (kA^2/(m1+m2))
v=0.601 m/s
How far apart are the masses when the spring is fully stretched for the first time?
This would involve finding the time that this occurs in order to get the distance. With the variables I have.. i don't know what to do next.. i have speed.. and masses..and an amplitude..Help?
Simple Harmonic Motion, Newton's 2nd Law, Hooke's Law, Law of Conservation of Energy
New amplitude of the block- m1-spring system :
[tex]\frac{1}{2}m_{1}v^2=\frac{1}{2}kA^2[/tex]
A=0.164 m with v is the speed of m1 and m2 at the equlibrium point.
Simple harmonic motion of the system :
x=Asinwt with A=0.164 m
[tex]-kx=m_{1}a[/tex]
[tex]a=-\frac{k}{m_{1}}x[/tex]
[tex]a=-w^2x[/tex]
[tex]w=\sqrt{\frac{k}{m_{1}}}[/tex]
[tex]x=Asinwt[/tex]
Left direction : Positive
When m1 is fully stretched for the first time, x=0.164 m, then
[tex]sin\sqrt{\frac{k}{m_{1}}}t=1[/tex]
t=0.428 s
m1 takes 0.428 s to be fully strecthed relative from the equilibrium point.
At this time interval, m2 has gone s=ut=0.257 m from the equilibrium point. so the distance between the two masses is 0.257m -0.164 m =0.093 m
To find the distance between the masses when the spring is fully stretched, we can use the equation for the displacement of a mass on a spring: x = A*cos(ωt), where A is the amplitude, ω is the angular frequency (ω = √(k/m)), and t is the time.
Since we know the amplitude (A = 0.220 m) and the angular frequency (ω = √(k/m) = √(122/9.04+7.31) = 3.641 rad/s), we can plug these values into the equation to find the time when the spring is fully stretched.
0.220 = 0.220*cos(3.641t)
cos(3.641t) = 1
3.641t = 0
t = 0 seconds
Therefore, the spring is fully stretched at t = 0 seconds. To find the distance between the masses at this time, we can plug in t = 0 into the equation for displacement:
x = A*cos(ω*0)
x = 0.220*cos(0)
x = 0.220*1
x = 0.220 m
Therefore, the masses are 0.220 m apart when the spring is fully stretched for the first time.
  • · Replies 16 ·
