| New Reply |
marble spiralling inside a cylinder |
Share Thread | Thread Tools |
| Aug17-11, 04:53 AM | #18 |
If I got hold of the wrong end of the stick then so could someone else. It would be quite possible to imaging a marble which was a hollow sphere and then things would be different. (The ratio would be 1, I think) Or a sphere with a lot of mass at the centre, where the ratio could be as small as you like.
Also there is an earlier post with a diagram of discs - which have a different MI from that of a sphere. The phrase 'uniform sphere' doesn't cost much to write and gives helpful precision. That's all but perhaps I was being too picky. |
| Aug17-11, 06:07 AM | #19 |
If you are so much into precision in language then you should have specified what mass distribution you assumed where the ratio is tiny, because it had obviously nothing to do with the marble discussed here. Instead you mentioned the size, which is irrelevant for the ratio. |
| Aug17-11, 06:17 AM | #20 |
Yes - I agree that size of similar objects has no bearing on it. |
| Aug17-11, 04:20 PM | #21 |
![]() ![]() Here the applet again: http://demonstrations.wolfram.com/Ro...sideACylinder/ |
| Aug17-11, 04:44 PM | #22 |
Yes we can and the animations are well done.
| Aug17-11, 05:00 PM | #23 |
| Aug17-11, 05:10 PM | #24 |
yebbut you found it. Don't be bashful. And it makes the point well.
| Aug21-11, 02:43 AM | #25 |
Here an experiment on this. In the second attempt the ball jumps back out, against gravity. Returning from a horizontal cylinder would be much simpler.
More info: http://www2.eng.cam.ac.uk/~hemh/movi...ballincylinder |
| Aug21-11, 11:01 AM | #26 |
Man, when you're right you're right.
I'd never heard of such a phenomenon but I'm sure aware of it now. Hat's off. |
| Aug21-11, 03:15 PM | #27 |
Recognitions:
http://www.youtube.com/watch?v=e-Skl2Z1wkg |
| Aug21-11, 03:21 PM | #28 |
But A.T.'s demos correlate so spectacularly with the observation of the OP that I'd say it's pretty much the final word on this thread. |
| Aug22-11, 07:54 AM | #29 |
| Aug25-11, 03:04 PM | #30 |
This bounce version is basically a discretized version of rolling in a cylinder. Here the momentum is transferred in a few discrete steps. It might be simpler to explain/understand than the contious rolling case. |
| Aug25-11, 05:23 PM | #31 |
I have no doubt that a superball can turn itself around. Anyone who's ever played with one can get it to spin off in wild directions. It's the whole point of a superball. Lot of mass, lot of friction.
I still do not see how one could ever do that with a glass marble. |
| Aug26-11, 06:31 AM | #32 |
| Aug26-11, 08:18 AM | #33 |
If I toss a superball at the ground, I get get it to do all sorts of tricks by playing with its spin. Effectively, I am applying English. Gyroscopy is one thing, but asymmetric reflection is another (because the spinning superball has grip). I just don't think it is possible to have a glass marble provide grip. A marble would not bounce back out of a box, because it will not be able to apply that force during contact. |
| Aug26-11, 08:46 AM | #34 |
If you throw a glass marble along a smooth plastic floor it starts rolling pretty quickly. So it does have enough traction, otherwise it would just slide. Why should it not roll in a cylinder? |
| New Reply |
| Thread Tools | |
Similar Threads for: marble spiralling inside a cylinder
| Pressure inside the cylinder | Introductory Physics Homework | 7 | ||
| Area of one cylinder inside another intersecting cylinder | Calculus & Beyond Homework | 6 | ||
| Spiralling Algorithm in C++ | Programming & Comp Sci | 3 | ||
| HELP: contact area of Cylinder inside a larger Cylinder? | General Math | 6 | ||
| B inside a cylinder of radius R | Introductory Physics Homework | 4 | ||
