| New Reply |
How to make water splash less? |
Share Thread | Thread Tools |
| Aug13-11, 05:55 AM | #1 |
Is there a term for the height that a liquid splashes above it's surface when a body falls into it?
There is a certain system in our house that is designed to drop viscoplastics at quasistatic speeds into a water vessel from a height of about 20 cm. Under normal operating conditions the water in the vessel does not splash onto the receptacle dropping the viscoplastics. However, this week the receptacle is ejecting a water-based substance at high speed, which causes the water in the vessel to splash up higher than normal. This is rather uncomfortable. Are there any common household products which one could add to water to reduce the height of the splash? I tried salt but there is no effective way of mixing it and it settles too quickly. Thanks. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Aug14-11, 01:37 AM | #2 |
put baffles in the tank.
| Aug14-11, 06:29 AM | #3 |
Thanks, Cragar. The tank is actually a toilet, and that would be hard to clean! I did find that draping two layers of toilet paper over the water does help, though.
| Aug14-11, 07:13 AM | #4 |
Mentor
How to make water splash less?![]() The original post here would make a great entry in a "Guess what is being described here" contest. ![]() But seriously, hope you're better soon dotancohen. |
| Aug14-11, 07:51 AM | #5 |
Mentor
| Aug14-11, 09:49 AM | #6 |
But it sounds like time for a contest! I'd love to see what others here come up with. |
| Aug14-11, 11:41 AM | #7 |
LOL!
How about increasing the viscosity of receptive fluid. Maybe Jello . . . . (BTW, the splash phenomenon described in the OP is known as 'Neptune's Kiss') |
| Aug14-11, 12:15 PM | #8 |
| Aug14-11, 12:43 PM | #9 |
Mentor
A friend of mine has suggested trying some olive oil, which would float on the surface.
| Aug14-11, 12:58 PM | #10 |
For the interested, talcum powder works as well by increasing the surface tension. Protip: powder it in when you leave so that it will be ready for when you return. You won't have the patience to powder properly when you need it. |
| Aug14-11, 01:03 PM | #11 |
I just found this thread:
http://www.physicsforums.com/showthread.php?t=69402 "Water wont splash in a vacuum" The OP of the thread asks about useful applications of this knowledge. I don't want to be the one to tell him about this application! |
| Aug14-11, 01:30 PM | #12 |
An alternative solution would be to lower the falling bodies slowly by a rope.
| Aug14-11, 03:54 PM | #13 |
As you described the problem is not the operation of the receptacle, it's the input that needs to be altered. May I suggest some sort of additive.
Something similar to this. Additive technical Specification |
| Aug14-11, 04:20 PM | #14 |
| Aug14-11, 04:26 PM | #15 |
Things are returning to normal now, though. I think posting about it helped. Oh no, I've become this: http://www.penny-arcade.com/comic/2008/4/23/ |
| New Reply |
| Thread Tools | |
Similar Threads for: How to make water splash less?
| Water and what make gas? | Chemistry | 24 | ||
| Water splash depth | General Physics | 5 | ||
| water doesn't splash in vacuum | Classical Physics | 1 | ||
| Wi-Fi phones make a splash | Computing & Technology | 0 | ||
