Ethel Alcohol vs Steam: Power Plant Turbines
  • Context: Undergrad
  • Thread starter Thread starter mat337d
    Alcohol Steam
Steam is the primary medium used to turn turbines in power plants due to its safety and cost-effectiveness compared to ethel alcohol. While ethel alcohol can produce more vapor and theoretically generate energy more quickly, its high combustibility and the need for specialized handling make it impractical for widespread use. Additionally, the cost of ethel alcohol is not competitive with water, and the risks associated with its use outweigh the potential efficiency gains. In Brazil, ethel alcohol is utilized as an alternative fuel due to local production capabilities, but adaptations are necessary for its use in conventional engines.
  • Understanding of steam turbine operation
  • Knowledge of heat of vaporization concepts
  • Familiarity with combustible materials and safety protocols
  • Awareness of alternative fuels and their economic implications
  • Research steam turbine efficiency optimization techniques
  • Explore the properties and applications of ethel alcohol as a fuel
  • Investigate safety measures for handling combustible materials
  • Learn about the adaptations required for using alternative fuels in engines
Engineers, power plant operators, safety professionals, and anyone interested in alternative energy sources and their practical applications in power generation.
mat337d
I have been told steam is used to turn turbines in a power plant. Why wouldn't they use ethel alcohol? It
has a lower heat of vaporization. So if I am not mistaken you would produce roughly twice as much ethel vapor to turn a turbine quicker generating more energy.Any help would be appriciated.
Science news on Phys.org
the problem with heating alcohol isthat its highly combustable and not cheaply available (not as cheap as water in the long run). So whilst you would produce more vapour or alcoholic steam, you would have to be careful to control the heat input or you could end up with a rather large and damaging fireball. Also people working with the alcohol would have to have special training and equipment etc. to use it which adds more to cost which in a business sense is really not viable. Simply put its too dangerous and too expensive.
On a different note alcohol is used in Brazil and other south american countries where they can produce vast quantities from sugar cane srocks as a cheap alternative to petroleum. The engines have to be adapted i believe so i wouldn't try it on your own car.
Thank you Kurdt.
So it is physically possible to gain a higher efficiency from ethel but not practical in a business sense.
  • · Replies 26 ·
  • · Replies 32 ·
