Maximum pull a of normal magnet
The discussion centers around the maximum pull of a normal magnet, specifically non-electromagnetic types like Neodymium magnets, and how this compares to electromagnets. Participants explore various aspects including strength, cost, immediate pull capabilities, and the differences between AC and DC electromagnets.
  • One participant questions the maximum pull achievable by a normal magnet the size of a computer mouse and compares it to an electromagnet of similar pull.
  • Another participant shares personal experience with Neodymium magnets, noting their strength and the difficulty in separating them once attached to a steel surface.
  • Concerns are raised about the immediate pull of electromagnets when the circuit is closed, with one participant stating that they achieve full force almost immediately, barring a slight delay due to hysteresis.
  • A participant warns against a previous suggestion for constructing an electromagnet, indicating potential dangers such as battery explosions.
  • Questions arise regarding the differences in power between AC and DC electromagnets, with one participant explaining that while there is no fundamental reason for a difference, factors like inductance and core losses could affect performance.
  • Another participant suggests that while making an electromagnet is feasible, it may not be strong enough to lift 100 pounds.
  • A request is made for resources that explain the technical details of electromagnet specifications, such as pull strength and power requirements.
Participants express differing views on the effectiveness and safety of constructing electromagnets, as well as the comparative strength of permanent magnets versus electromagnets. The discussion remains unresolved regarding the optimal methods and specifications for achieving desired pull strengths.
Participants mention various assumptions regarding the strength of magnets, the safety of using certain materials, and the potential hazards of different power sources. These factors remain unresolved and depend on specific conditions and definitions.
This discussion may be useful for individuals interested in magnetism, electromagnet design, and practical applications of magnets in experimental settings.
BasketDaN
What is the maximum pull a normal magnet (non electromagnet) of about the size of a computer mouse could achieve? And how would the cost of this compare to the cost of an electromagnet of the same pull? Also, will an electromagnet achieve it's desired pull immediately when the circuit is closed? Thanks.
Hard to give exact figures, but I've just bought some incredibly strong Neodymium magnets to play with in the Lab. These are AWESOME! If you put a 2" x 3" magnet on a steel surface you can't lift it off!
I bought 10 small 1" round magnets and one big one and when they are together I struggle (and I mean struggle!) to pull them apart. They also jump back together and can really hurt when they pinch your skin. When handling them, you have to hold them tight or they jump out of your hands if they are near another magnet.
I'll see if I can measure the force needed to separate them later this week.
In the meantime - buy some on Ebay. I bought mine from this great Ebay store:
PowerMagnetStore.com
If you need a strong magnet quick , don't bother with permanent magents. Electromagnets do get the full force just about immediatly
(if you can wait the fraction of a second for hysteris).
I used neodymium magnets myself, very extremely powerful, and potentially dangerious.
If you are going to manufacture an electromagnet use iron or something as the core for the inductor. If you can get your hands on some finishing nails, then duct tape them into a role, and then wrap that with wire, it works wonders, just use a nine volt battery at either end of the wire terminals. Their you'll have a magnet stronger then any neodymium magnet you could buy.
Do Not follow the last advice you may explode the batteries -- for some people there is no hope !
Thanks guys.
Is there a significant difference in the power of an electromagnet using AC current and one using DC current?
How long would you guess a few D batteries or 9V or w/e would last that could power an electromagnet with a pull of about 100 pounds? I'm not sure if my question is answerable because I don't really know what I'm talking about.
There is no basic reason for AC to be different from DC since AC can be as slow as you like -- however if the AC if fast then you must allow for a) the inductance of the winding which will reduce the current for a given input voltage and b) there are core losses due to hysteresis ( ie. heat produced in the core over and above any dc loss in the winding ). For normal house ac the effects are probably not large .
In any event trying to produce strong electromagnets with house ac is a little dangerous, it would be adviseable to do a few simple calculations on resistance , power , etc to avoid fire hazards aside from the chance of shock -- this is also true of using NI Cads etc you should limit the currents to avoid battery heating ( suggest you contact a supplier for info on this ) I.e. Max allowable sustained current drain .
Ray.
If you have an old computer hard disk it has some really good magnets in it. (and i mean good as in you REALLY don't want to get your finger stuck between them ).
If you can't find one though, making an electromagnet is quite easy, although a bit time consuming. I don't think it will be strong enough to pick up 100 pounds though
Could anybody direct me to a site that explains a fair amount of technical details about how an electromagnet's pull, watt requirements, voltage, size, etc. all relate?
Thanks.
Try 'Howstuffworks' as a start . Ray
  • · Replies 40 ·
  • · Replies 21 ·
  • · Replies 24 ·
