CLUELESS about a Maclaurin series
The discussion revolves around obtaining a Maclaurin series for a piecewise function defined as \( f(x) = e^{-1/x^2} \) for \( x \neq 0 \) and \( f(0) = 0 \). Participants are exploring the implications of undefined derivatives at \( x = 0 \) and the relationship between the Maclaurin series and the function itself.
  • Participants discuss the evaluation of derivatives at \( x = 0 \) and question the validity of the original poster's findings regarding undefined derivatives. There are attempts to clarify the nature of the function's differentiability and the implications for the Maclaurin series.
The discussion is ongoing, with various interpretations of the function's behavior at zero being explored. Some participants suggest that the original poster's approach may need reconsideration, while others provide insights into the nature of derivatives and limits.
There is a focus on the undefined nature of derivatives at \( x = 0 \) and the implications for constructing the Maclaurin series. Participants are also considering the differentiability of the function near zero and the requirements for a valid Maclaurin expansion.
DivGradCurl
CLUELESS about a Maclaurin series!
I'm supposed to obtain a Maclaurin series for the function defined by
[tex]f(x) = \left\{ \begin{array}{lc} e^{-1/x^2} & \mbox{ if } x \neq 0 \\<br /> 0 & \mbox{ if } x = 0 \end{array} \right.[/tex]
I get immediately stuck as I find:
[tex]f(0) = 0[/tex]
[tex]f^{\prime}(0) = \mbox{ undefined }[/tex]
[tex]f^{\prime \prime}(0) = \mbox{ undefined }[/tex]
[tex]f^{\prime \prime \prime}(0) = \mbox{ undefined }[/tex]
[tex]f^{(4)}(0) = \mbox{ undefined }[/tex]
So,
[tex]f^{(n)}(0) = \mbox{ undefined } \qquad n > 0[/tex]
Thus, we may write
[tex]f(x) = f(0) + \frac{f^{\prime}(0)}{1!}x + \frac{f^{\prime \prime}(0)}{2!}x^2 + \frac{f^{\prime \prime \prime}(0)}{3!}x^3 + \cdots[/tex]
Question
How do I handle the undefined results? (I'm supposed to show that the Maclaurin series is not equal to the given function)
Thank you very much. :smile:
Not sure if this is right or not. We know that [tex]f'(x) = \left\{ \begin{array}{lc} e^{1/x^3} & \mbox{ if } x \neq 0 \\<br /> 0 & \mbox{ if } x = 0 \end{array} \right.[/tex] So [itex]f'(0)=0[/itex], which is well defined.
You messed up the chain rule, Corneo.
Thiago: are you sure f'(0) is undefined?
0 is a constant.
What's the derivative of any constant?
--J
Thanks for your input, guys.
Justin, I don't think I should take the derivative of f'(0) = 0 (and then take the derivative of this constant), but instead find each derivative and later evaluate at x = 0. This is how I got my results.
Hurkyl, here you go:
[tex]f^{\prime} (x) = \frac{d}{dx} \left( e^{-1/x^2} \right) = \frac{2e^{-1/x^2}}{x^3} \Longrightarrow f^{\prime} (0) = \mbox{undefined}[/tex]
I've just evaluated that over again in TI, and this time I also calculated
[tex]f(x) = 0 + \mbox{undefined} +\mbox{undefined} + \mbox{undefined} + \cdots = \mbox{undefined} \neq \left\{ \begin{array}{lc} e^{-1/x^2} & \mbox{ if } x \neq 0 \\<br /> 0 & \mbox{ if } x = 0 \end{array} \right.[/tex]
which sounds reasonable, since I need to show they're not equal.
Looks to me like you've done that.
Ah, but near zero, the function is not defined as [itex]f(x) = e^{-1/x^2}[/itex]!
that is, at zero, you mean. but yeah, that fact makes the function differentiable at zero (some tinkering indicates the lim of f(x)-f(0)/(x-0) as x goes to zero exists and is zero now that f(0) is defined; should doublecheck, though), so you can write a Maclaurin expansion that'll fail.
thiago_j - i think you're a bit confused about this, the derivative of 0 is not, in general, undefined (though it can be when a function is not differentiable at 0).
