What causes some liquids to evaporate more quickly
  • Context: High School
  • Thread starter Thread starter Rockazella
    Liquids
The discussion revolves around the factors influencing the rate of evaporation of different liquids at the same temperature, with a specific focus on the roles of kinetic energy, potential energy, and molecular interactions. Participants explore theoretical concepts related to phase changes and the properties of liquids.
  • Some participants propose that the kinetic energy of molecules is a key factor in evaporation rates, questioning why some liquids evaporate more quickly than others at the same temperature.
  • Others argue that the specific heat of a liquid influences the energy required for phase changes, suggesting that different liquids have varying energy thresholds for evaporation.
  • A participant mentions surface tension as a factor, noting that lower surface tension in gases allows molecules to escape more easily.
  • One participant raises a question about the relationship between kinetic and potential energy during phase changes, expressing confusion over how potential energy can increase without a corresponding increase in kinetic energy.
  • Another participant introduces the concept of gravitational potential energy in relation to molecular distance, suggesting that greater distances between molecules may correlate with higher potential energy.
  • Some participants express uncertainty regarding the explanation of potential energy and its relationship to kinetic energy, with requests for clarification and additional resources.
Participants do not reach a consensus on the relationship between kinetic and potential energy in the context of phase changes. Multiple competing views and uncertainties remain regarding the factors influencing evaporation rates and the underlying molecular mechanics.
Limitations include varying definitions of potential energy and kinetic energy, as well as differing interpretations of phase change mechanisms. The discussion does not resolve these complexities.
Rockazella
I know it's the kinetic energy (temp.) of the molecules that controls evaporation. Just wondering what causes some liquids to evaporate more quickly than others at the same room temp... for example gasoline?
Science news on Phys.org
It depends on how much heat it takes to make the transition. A higher specific heat means more energy required to reach the same temperature. The temperature at which they make a phase change can be different. The energy required to make the phase change also varies.
Another key factor is surface tension, gas has a very low surface tension, this allows molecules to escape the fluid at a lower velocity, thus lower liquid temperature.
Alright those make sense, thanks.
I have a follow up question that's slightly off topic of the first:
When I posted the first question I was under the impression that phase change was due to greater kinetic energy of the molecules. However, since posting it I've done a bit of reading online. The site I read said that phase change occurs because of an increase in potential energy of the molecules. It explains the potential energy of molecules as the average distance between them, greater distance= greater potential energy. I must say, I don't understand this. Seems to me that a greater average distance will be the result of higher velocity or more kinetic energy. Can anyone help me to make sense of this molecular potential energy concept?
itim not an expert so I am not goin to attempt to make a feeble explanation but it has to do with the electrons phase shifting or juming from one energy level to another
Pop676: "electrons phase shifting or juming from one energy level to another" produces light. I don't see what that has to do with evaporation.
I believe that it is true that liquids consisting of less massive molecules evaporate more quickly.
I'll try...
I will try to answer but I want you to know that I'm not an expert too.
First of all the gravitational potential energy (there are others) depends on the distance between the molecules, like it does between you and the Earth. The higher distance is the higher potential energy you have. Maybe they meant distance by saying 'potential energy'. Can I be right?
Best wishes
Kish,
yes you could be right, but my question is what's maintaining that greater distance AND what would cause the molecules to all of a sudden go farther apart? Like I said before, it seems to me that only a greater kinetic energy would do this(a molecule with more velovity would be able to get farher away from another molecule before it turns back). Yet, what I read says when phase change ocures the kinetic energy practically stays the same, but the potential increases. Not to be repetative, but I'm not understand how a molecules PE can go up without it be caused by a greater KE.
I have no idea...:frown:
Rockazella,
Could you post the original
paragraph explaining that, verba-
tim? Or a link? That is very con-
fusing to me as well.
-zoobAlso, here is a link to an article
that goes into detail about your
first question, and explains it
pretty well:
vapor pressure (Chemistry, General) - 1Up Info - Encyclopedia
Address:http://www.1upinfo.com/encyclopedia/V/vaporpre.html
  • · Replies 32 ·
15K
10K
