Bending moments diagram at T intersection
The discussion focuses on calculating axial force, shear force, and bending moment diagrams at a T intersection in structural analysis. The user is uncertain about how to approach the intersection at point D, specifically whether to evaluate it from D-E while treating the post from D-F as a pin joint. A solution is provided, indicating that section DE acts as a cantilever, allowing for straightforward calculations of shear and moment at that section using a Free Body Diagram (FBD).
  • Understanding of Free Body Diagrams (FBD)
  • Knowledge of shear force and bending moment calculations
  • Familiarity with cantilever beam behavior
  • Basic principles of structural analysis
  • Study the principles of Free Body Diagrams in structural mechanics
  • Learn how to calculate shear and moment diagrams for cantilever beams
  • Explore the concept of pin joints in structural analysis
  • Review examples of T intersections in beam analysis
Structural engineers, civil engineering students, and anyone involved in analyzing forces and moments in beam structures will benefit from this discussion.
mackhina
Draw the axial force, shear force and bending moment diagrams. Show the locations and magnitude of the maximum and minimum values.
See diagram.
I've worked out the values from points A-B and then from points B-D. I don't grasp how I am suppose to approach the T intersection at point D. Should I evaluate it from D-E and treat the post from D-F as a pin joint, with values of 36.13kN and 15.13kN?
Then do the joint D-F after? If the D-E sections wasn't there I would just continue working around from D-F next, but because it is I'm not sure of how to work it out?
Any help would be heaps appreciated. Thanks a lot!
Cheers
Section DE is just a cantilever. If you cut a section thru DE in a FBD that includes the 10 kN force, the shear and moment at that section are easily calculated (no axial force). In DF, your FBD is similar to that of AB ( but with different values).
  • · Replies 16 ·
