Inclined Plane Friction Question
The discussion centers on calculating the coefficient of kinetic friction for a mass sliding down an inclined plane with an angle of 31.1 degrees. The mass starts at a speed of 2.13 m/s, slides 1.24 m down the incline, and then travels 2.45 m on a flat surface before stopping. Initial calculations yield a coefficient of friction of approximately 0.357, but further analysis suggests that if friction is present on the incline, the coefficient could be as low as 0.248. The participants emphasize the importance of correctly applying energy conservation principles and accounting for forces acting on the mass.
  • Understanding of mechanical energy conservation principles
  • Familiarity with kinematic equations and free body diagrams
  • Knowledge of frictional forces and coefficients of friction
  • Basic trigonometry, particularly sine functions for incline calculations
  • Study the application of energy conservation in inclined plane problems
  • Learn how to derive the coefficient of kinetic friction using work-energy principles
  • Explore the effects of friction on inclined surfaces in detail
  • Review kinematic equations and their application in real-world physics problems
Students and educators in physics, engineers working on mechanical systems, and anyone interested in understanding the dynamics of motion on inclined planes and the effects of friction.
pulau_tiga
Hi.
I was wondering if anyone could help me out in this question:
A mass M is sliding down the inclined plane at a speed of 2.13 m/s. The mass stops a distance of 2.45 m away from the base of the inclinde, along a flat surface. The mass slides 1.24 m down the incline before reaching the horizontal surface. The inclide has an angle theta of 31.1 degrees above the horizontal. Calculate the coefficient of kinetic friction for the mass on the surface.
I said that
Mechanical energy@ topof the incline = Mechanical energy@bottom
KE(top) + PE(top) = KE(bottom) + PE(bottom)
0.5m(Vtop^2) + mgh = 1/2m(Vbottom^2) + 0 J
Solving for Vbottom = 4.14 m/s
**I said that h = sin(theta) x 1.24 m; h=0.641 m
Then by using Vf^2 = Vo^2 + 2ad, and solving for acceleration, given that Vf=0 m/s (when it comes to a stop), and Vo = 4.14 m/s(the velocity at the bottom of the incline), and d = 2.45 m
I got an acceleration of -3.50 m/s^2
then looking at a freebody diagram, I said that the sum of all forces in the x-direction is = ma.
I only have friction acting in the x direction?? Is there another force?
I said. -f=ma
-(mu)FN = ma where mu=coefficient of friction, FN = normal force
-(mu)mg= ma mg=FN, because, FN=Fg
masses cancel, and solving for mu...
mu = -0.357,
but, mu cannot be -?? and 0.357 is not the answer.
If anyone could help me out, it would be greatly appreciated thanks!
Is there friction on the incline? Is 2.13 m/s the initial speed of the mass at its starting point on the incline?
I said that
You assume no friction on the incline. If so, your method is good, but check your arithmetic.
As far as [itex]\mu[/itex] being negative, I'm glad you realize that that makes no sense. The magnitude of the kinetic friction force = [itex]\mu N = \mu mg[/itex].
Hi Ho! ^_^
Assuming that there's no frictional force on the incline, you got the right answer.
You forgot to include the minus sign for the acceleration.
Thus, -f = ma
-(mu)mg = m(-3.50)
The sign cancels and you'll get mu = 0.357 (I found it to be 0.356).
If that's not the answer, then there's frictional force on the incline.
Next time, better you use isolated system method.
Like what I have learned from Fundamental of Physics 6th edition by Halliday/Resnick/Walker.
So you doesn't need to do kinematics to find the acceleration and drawing the free body diagram.
I'll show you how.
Let's take an isolated system consists of: ramp-surface-earth-mass.
Because there's no external force acts on it, Work by external force = (delta)Energy of the isolated system = 0.
Thus, W = (delta)K + (delta)Ugravitation + (delta)Ethermal
0 = 0.5*m*(0 - 2.13^2) + m*g*(0 - 1.24*sin(31.1)) + (muk)*m*g*2.45
(delta)Ethermal = fk*d = (muk)*m*g*d
Solving for muk yields 0.3559084970
Same result with less effort for sure.
Now I will solve for muk if there's frictional force on the incline.
0 = 0.5*m*(v^2 - 2.13^2) + m*g*(0 - 1.24*sin(31.1)) + (muk)*m*g*cos(31.1)*1.24 ...(1)
(delta)Ethermal = fk*d = (muk)*N*d -> For inclined surface, N = m*g*cos(theta). Where fk is kinetic frictional force.
0 = 0.5*m*(0 - v^2) + 0 + (muk)*m*g*2.45 ...(2)
Substituting (2) to (1) for v yields:
0 = 0.5*m*(2*(muk)*g*2.45 - 2.13^2) + m*g*(0 - 1.24*sin(31.1)) + (muk)*m*g*cos(31.1)*1.24
Solving for (muk) yields:
muk = 0.248
So, any comments for this? If 0.248 is not the answer either, I think the problem or its data is wrong.
  • · Replies 33 ·
