New Reply
Firing angle in rectifiers and inverters.
Share Thread Thread Tools
Aug16-11, 05:15 PM   #1
Hello everyone I am a newbie to electrical engineering, I have this problem I've been strugling with, no textbook seems to cover this problem..
A three-phase, 440-V, generator delivers 5400W of active power through two recti-fies, A and B, into a three-phase, 230-V, line as shown in Figure 3.
The dc current through the inductor is 20A. If power loss in both rectifiers are negligible, calculate:
(a). Firing angle of the rectifier A;
(b). Firing angle of the rectifier (inverter) B.
This is my attempt ;
V out = 5400/ 20 = 270
For inductive load
VOUT = 1.35 × VLINE × cos α
Where ‘α’ is the firing angle of the rectifier.
Therefore,
cos α = V / 1.35 x Vline
α = 29
how does this seem? and how is the inverter's firing angle different?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Aug17-11, 09:36 AM   #2
2. Relevant equations
3. The attempt at a solutionThis is my attempt ;
For inductive load
Therefore,
α = 29
Aug18-11, 04:03 AM   #3
Recognitions:
Homework Helper Homework Help
Where is Fig 3?
Aug18-11, 09:48 AM   #4
here's the figure :D
http://imageshack.us/photo/my-images/69/figure3t.png
Aug18-11, 11:48 AM   #5
Recognitions:
Quote by ramox3 View Post
For inductive load
Therefore,
α = 29
Seems ok. And you can use the same formula (with the relevant line voltage) for the inverter side.
BTW The constant 1.35 comes from 3 sqrt(2) / pi.
Aug18-11, 12:41 PM   #6
Quote by uart View Post
but what is the relevent line voltage for the inverter? isn't it the same?
Aug19-11, 05:15 PM   #7
Not sure this is the right place to post this (perhaps this is why no one answers, but I don't know I'm new to PF). Here's some help:
In fact, there are a lot of text books that cover this. For instance see "Power electronics", from Mohan. I can't see your Figure 3, but I assume you have a perfect voltage source connected to 2 full-bridge thyristor converters (1 rectifier, 1 inverter) and some load. There should also be an inductor on the DC bridge. To find the solution for rectifier A (source):
[tex]P=V_{DC}I_{DC}[/tex]
where the voltage on the DC bus is given by:
[tex]V_{DC}=\frac{3\sqrt{2}}{\pi}V_{LL}\cos{\alpha}[/tex]
where [itex]V_{LL}[/itex] is the line-line voltage of the AC side. The DC bus current is given in the problem, which is [itex]I_{DC}[/itex]. Just isolate these for [itex]\alpha[/itex]...
For rectifier (inverter) B, same procedure, but by using a negative power and use the 230V line-line voltage. Isolate again for [itex]\alpha[/itex]... This angle should be between 90 and 180 degrees since this converter is operating in inverter mode.
M.
Aug19-11, 06:09 PM   #8
Mentor
(Moderator's note -- two threads merged...)
New Reply
Thread Tools
Similar Threads for: Firing angle in rectifiers and inverters.
Thread Forum Replies
alternating current and rectifiers Classical Physics 1
Inverters and Power Consumtion? Electrical Engineering 2
Using DC-AC inverters in parallel Electrical Engineering 4
Bridge Rectifiers Introductory Physics Homework 3
DC-AC inverters and wall outlets Electrical Engineering 2
