Probability of being a Superset
  • Context: Graduate
  • Thread starter Thread starter claytondaley
    Probability
The discussion revolves around the interpretation and implications of a probability statement related to propositional logic, specifically examining the equation P(h⊃b|e) = P(¬h∨b|e) as presented by Ilkka Niiniluoto. Participants explore the relationship between logical implications and probability measures, questioning the validity and interpretation of the notation used in the context of induction and deductive reasoning.
  • One participant expresses uncertainty about the rationale behind the equation P(h⊃b|e) = P(¬h∨b|e), suggesting it may relate to Hempel's paradox and the nature of inductive reasoning.
  • Another participant argues that the fallacy lies in assuming A is already true in the implication A → B, emphasizing that the discussion should focus on the correct interpretation of logical connectives.
  • A different participant notes that probability measures are typically applied to sets and questions whether Niiniluoto's paper defines probability in a different context, asserting that the equivalence of the two propositions should not be surprising.
  • One participant attempts to clarify the relationship between the expressions h⊃b|e and b→h|e, indicating a need to establish the correct interpretation of the notation used.
  • Another participant raises questions about whether the variables h, b, and e represent sets or propositions, which affects the interpretation of the logical statements.
  • Further clarification is sought regarding the translation of logical symbols, with one participant expressing uncertainty about their correct usage in the context of the discussion.
  • Another participant emphasizes the importance of understanding the definitions of notation across different texts, noting that symbols can represent both sets and propositions, which can lead to confusion.
Participants do not reach a consensus on the interpretation of the probability statement or the underlying logic. Multiple competing views remain regarding the nature of the variables involved and the implications of the logical expressions.
There are limitations in the discussion regarding the assumptions made about the notation and the context in which probability is applied. The interpretations of the symbols used are not standardized, leading to potential misunderstandings.
claytondaley
Let me start by saying I'm an amateur insofar as I took one propositional logic course in college and have self-taught everything else so I may be missing something obvious. However, I was reading an article by Niiniluoto (1972) and (with respect to induction) he makes the following statement:
(2) P(h[itex]\supset[/itex]b|e) = P([itex]\neg[/itex]h[itex]\vee[/itex]b|e)
Can someone confirm the rationale for this? I assume this is the stastical calculus version of Hempel's paradox. Specifically, the deductive version of this argument (and presumably the assumption used by Nicod and Niiniluoto) arises from the idea that:
(a[itex]\rightarrow[/itex]b) [itex]\rightarrow[/itex] ([itex]\neg[/itex]b[itex]\rightarrow[/itex][itex]\neg[/itex]a)
The idea being... since the second is deduced from the first, evidence for the second supports the first. However, it's trivial to create an inductive state where this is not true. Assuming this is a table of observations (column labels above, row labels to the right):
| a | [itex]\neg[/itex]a |
| 8 | _0 | _b__
| 2 | _1 | [itex]\neg[/itex]b__
In this situation
a[itex]\rightarrow[/itex]b (80%)
is clearly probable. However,
[itex]\neg[/itex]b[itex]\rightarrow[/itex][itex]\neg[/itex]a (33%)
does not follow. Intuitively, it seems to me that (in an inductive context at least) the observation of a shoe, no matter its color, can never disconfirm the hypothesis. As a consequence, it ought not confirm the hypothesis. "All" should only apply to objects/observations that can disconfirm the theory.
What got me to the above explanation was my initial intuition that we care about the proportion of b[itex]\wedge[/itex]e that falls into h[itex]\wedge[/itex]e rather than including, for some reason, all of [itex]\neg[/itex]h including the region that is both [itex]\neg[/itex]h and [itex]\neg[/itex]b. For example, I believe what I'm saying is properly stated as:
P(h[itex]\supset[/itex]b|e) = P(h|b[itex]\wedge[/itex]e)
I have trouble imagining that there isn't some kind of response within Nicod's paradox for what I've described... but I can't for the life of me figure it out (or even how to look for it).
P.S. appologize in advance for any mistakes in Latex formatting (or propositional logic)
Ilkka Niiniluoto (1972) Inductive Systematization: Definition and a Critical Survey. Synthese, Vol. 25, No. 1/2, Theoretical Concepts and Their Operationalization (Nov. -Dec., 1972), pp. 25-81
The fallacy here is that you're assuming that A is already true in a -> b.
A -> B is true if ~A is true or if B is true. You're looking at A ^ B, not A -> B. Contraposition does not work for the "and" connective.
Usually probability measures are applied to sets and in most mathematical discussions when we speak of the probability of a statement or proposition, we are (according to the conventional point of view) supposed to realize that we are really speaking of a probability of a set of some sort. I don't know whether the paper that you cite is attempting to define probability in a different context.
The proposition "if A then B" is logically equivalent to the proposition " (Not A) or B". This can be verified by comparing the truth tables for the two propositions. I've seen this fact referred to as "material implication" in logic textbooks. So there is nothing suprising about eq 2. How could the probability of two identical things not be the same?
I spent like an hour searching the internet for the probability calculus of supersets (which is where I really got stuck) before I asked the question here. Let me take a step back and checking that this is true:
h⊃b|e = b→h|e
(obviously taking all the probability elements out of the statement)
My instinct is to say "yes, of course", but I suppose we should go through the formality of establishing exactly what you are talking about. The main difficulty in answering your question is interpreting your notation.
Are the variables involved in [itex]h \supset b | e[/itex] sets or are they propositions? If they are sets, how do you interpret [itex]x \supset y[/itex] as a set when [itex]x[/itex] and [itex]y[/itex] are known sets? If they are propositions, how do you interpret " | e" ?
Sorry, maybe i copied his stuff wrong... I'm pretty sure i follow/understand the language but am not 100% confident in its conventions... for example I thought it was safe to translate ~ to ¬ (which appears to be true) but maybe not equally , to |
his exact formulation is
P(h ⊃ b , e) = P( ~h ∨b , e)
Eliminating the probabilities, I interpeted this as
(b => h) | e = (~h ∨b) | e
If my interpretation is right, (b => h) translates to (~b ∨ h) rather than (~h ∨b). So likely my interpretation is wrong but I need to know where so I don't repeat it.
You still didn't say whether the letters represent sets or propositions.
Taking the letters to represents propositions ( for example "H" to mean "Merle Hedley is healthy" ) then I interpret
"[itex]H \supset B[/itex] " to mean "[itex]H[/itex] implies [itex]B[/itex]" or, equivalently, "if [itex]H[/itex] then [itex]B[/itex]".
The only way I see to interpret " [itex]( H \supset B) | E[/itex] as a proposition is "( [itex]H[/itex] implies [itex]B[/itex] ) and [itex]E[/itex]".
With those interpretations, [itex]( H \supset B) | E[/itex] is logically equivalent to "((not [itex]H[/itex] ) or [itex]B[/itex]) and [itex]E[/itex]", which could be abbreviated by "[itex](\neg H \vee B) | E[/itex]".
People use symbols like "=", "[itex]\cup[/itex] ", "[itex]\vee[/itex] ", " [itex]\supset[/itex]" and "[itex]\neg[/itex] " both for the algebra of sets and the algebra of propositions. You have to pay attention to how the material you are reading defines its notation. Such notation is not standard across all textbooks.
If we interpret the symbols as sets, the only interpretation that makes sense for "[itex]H \supset B[/itex]" is the set "[itex]H[/itex] complement union [itex]B[/itex]". If you try to interpret "[itex]H \supset B[/itex]" as the statement "[itex]H[/itex] is a supserset of [itex]B[/itex]" then you would be trying to apply the probability operator "[itex]P[/itex] " to a proposition on the left had side of eq 2 and apply it to a set on the right hand side of eq. 2.
Appologize for not following the question and thanks for the clarification. While the implications are a little hazy, I at least see the difference in the context. He states:
"all statements b, e, and h"
... and using his formulation of the "Deductive Theorum" plus wikipedia's version, ⊃ is → as you stated.
  • · Replies 20 ·
  • · Replies 31 ·
  • · Replies 54 ·
  • · Replies 63 ·
9K
  • · Replies 50 ·
13K
