| Thread Closed |
Hydrofoil design verification |
Share Thread | Thread Tools |
| Nov10-04, 03:47 PM | #1 |
I downloaded a hydrofoil simulation calculator and wanted to verify the results I am getting.
Can someone tell me if the following numbers are accurate? I am trying to get the highest amount of lift I can for a constant water velocity over hydrofoil of 20m/sec or 38.9Knots. I am also trying to keep the foil span as short as possible. Here are the input numbers: Foil Area Square Meters: 1 Sq M (1M span X 1M chord) Speed M/sec: 20 M/sec density of water kg/m^3: 1000 thickness of foil divided by chord: 0.5 Aspect ratio (Foil span/chord): 1 "This is a square foil I know" Angle of attack: 14.32 degrees Profile Curvature: 0.25 The calculation is claiming that the hydrofoil would produce 53690 pounds of lift with these numbers. I need to make sure this is true and also that the wing is not in a stalled state on these numbers. Greatly appreciated. Sidenote: Would anything change if I put a rectangular ducting around the hyrdrofoil? I know in airfoils and fans, the ducting produces more volume of airflow. BE |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Hydrofoil design verification
| More verification of HUP | Quantum Physics | 5 | ||
| If Intelligent Design is exactly that, what's with all the design flaws? | Current Events | 62 | ||
| verification | Classical Physics | 5 | ||
| Hydrofoil puzzler | Mechanical Engineering | 0 | ||
