New Reply
Volume Contraction (Water & Methanol Mixture)
Share Thread Thread Tools
Aug17-11, 06:45 AM   #1
Hey there. I've been searching the internet on volume contraction with water and methaol mixture. Although I have found a little bit of infomation I don't know why it happens.
I found it quite intriguing that mixing 50ml of water and 50ml of Methanol =/= 100ml of liquid. Infact there is a 4% difference.
I know it has something to do with the strength of the hydrogen bond, but is there anything else that affects this. Size of the hydrocarbon? Temperature? Percentage of Mixture? if so, I cannot find much on this on the internet.
I'd like to know more about this it does seem very interesting.
Does anyone else know anything about Volume Contraction in Methanol & Water mixtures?
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Detecting mirror molecules: New technique reliably tells left-handed from right-handed variant of a compound
>> Chemists devise inexpensive, accurate way to detect prostate cancer
>> Overcoming resistance to anti-cancer drugs by targeting cell 'powerhouses'
Aug17-11, 07:29 AM   #2
I think some factors could be applied. Size of the molecule might be a factor, because the larger the alcohol molecule is, the less significant the hydrogen bond appears. Because non-polarised parts prefer join with other hydrophobic parts, which means attraction between alcohol and water molecules becomes less significant.
Also, temperature, I guess, has significant impact on strength of hydrogen bonds. As the more violent the movement of molecules is, the more possible that the bonds could break. I don't quite know many details involved, and you probably require more authoritative answers.
Aug20-11, 10:39 PM   #3
Quote by miniradman View Post
So what you are suggesting is that when you mix equivalent volumes of CH3OH and H20 you do not get 100mL of solution in your vessel? My thinking is that the -OH group on the methyl group is a electron withdrawing functional group and will shift the electron density toward the -OH region of the molecule, creating a small dipole moment. This can interact with the polar water molecules so what you have is some limited miscibility. I think increasing the temperature (increasing the kinetic energy of the molecules in solution) of the system would facilitate the solution process and make both substances more "agreeable" with each other. The -OH group on alcohols makes them useful as solvents for both polar and non-polar substances so, however I would not expect the methanol and water to be perfectly miscible with each other.
Aug21-11, 03:10 AM   #4
Admin
You don't need any fancy interactions for volume contraction, add sand to marbles and final volume is lower than the sum of volumes.
Aug21-11, 04:49 AM   #5
Quote by c03rcion View Post
Interesting, I've always thought that intermolecular forces were at play here. But I haven't looked at it that way...thanks mate
Quote by Borek View Post
Yeah, that would work. But it wouldn't show how different temperatures affects volume contraction
Aug21-11, 05:36 AM   #6
Fra
Not sure about methanol but ethanol/water mixtures density are defined in tables/graphis in handbook of chemistry and physics.
If you have access to that book, have a look.
/Fredrik
Aug23-11, 11:12 PM   #7
Other Sciences 2012
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
It works with water due to the unique structure of water in the liquid state. Liquid water is a fairly open network of hydrogen bonds. Methanol (and ethanol) get in there and mess up the latticework a bit. The more open pure water hydrogen bond network is altered by that methyl group and the whole house of cards comes down.
Be careful where you go looking for answers to this question. I've seen answers on Yahoo Answers that claim that ethanol molecules are smaller than water molecules and they can slip between those big 'ol water molecules! Were that true, the ethyl group would need to be substantially smaller than a hydrogen atom!
Oh yeah, methanol and water are completely miscible in all proportions as is ethanol and water.
Aug24-11, 07:11 AM   #8
Sorry, I was meant to say Ethanol... sorry
Could someone please explain how the abundence of electrons on the end of the hydroxyl group affect volume contraction?
I can't find anything on the internet or the books.
Feb6-13, 09:32 PM   #9
I have been reading about this in the pchem book as well. I thought it was interesting indeed. Of course, I cound not find any good explanation online and eventually ended up here!
Thermodynamics have been an active research in the 1900s but I doubt it still is right now.
Here is a paper that one might be interested in reading.
Its paper about mixing methanol and water. Methanol has much lower molar volume than water. But upon addition of methanol, molar volume do not change for a while. It is different from ethanol one where volume just decrees and then goes up to ethanol's molar volume(not sure if ethanol has higher molar volume)
by A. J. Easteal and L. A. Woolf. Journal of CHem. Thermodyn.
Feb7-13, 03:05 AM   #10
Admin
Quote by soohyun2222 View Post
Is this an exercise in misreferencing?
Feb7-13, 12:59 PM   #11
Was in a hurry I forgot to add the rest. A.J. Easteal and L.A. Woolf, J. Chem. Thermodyn., 17, 49 (1985)
Feb8-13, 06:17 AM   #12
Recognitions:
To get further insight, you could also study e.g. a two component van der Waals equation.
New Reply
Tags
alcohol, hydrocarbon, methanol, volume contraction, water
Thread Tools
Similar Threads for: Volume Contraction (Water & Methanol Mixture)
Thread Forum Replies
Cooling of water vapor - air mixture to T < 273K General Physics 1
A saturated mixture is heated, volume is doubled and pressure remains the same. Engineering, Comp Sci, & Technology Homework 1
water in methanol General Physics 1
How do I determine volume of salt water mixture before mixing? Chemistry 3
Temperature of ice-water mixture Introductory Physics Homework 12
