Hardest AP PHysics lab EVERRRRRR
This discussion focuses on calculating the thrust of a water rocket using a 2-liter soda bottle. Key equations include M*(delta)v=dm*Ve and Vf-Vi=Ve*ln(Mi/Mf), which relate thrust to mass and velocity changes. The thrust can be expressed as Thrust = Ve*(dm/dt) = M*(dv/dt), where Ve is the exhaust velocity. The analysis emphasizes the application of Newton's second law, particularly in scenarios where mass is not constant.
  • Understanding of Newton's second law of motion
  • Familiarity with the concept of thrust in rocketry
  • Knowledge of conservation of momentum principles
  • Basic calculus, specifically the chain rule
  • Explore advanced applications of Newton's second law in variable mass systems
  • Research the principles of rocket propulsion and exhaust velocity
  • Learn about the derivation and application of the Tsiolkovsky rocket equation
  • Investigate experimental methods for measuring thrust in water rockets
Students in AP Physics, educators teaching physics concepts, and hobbyists interested in rocketry and experimental physics.
the4thcafeavenue
now guys, i need your help. in this lab, i am making a rocket with a 2 litter soda bottle with water inside, and air will be pumped in so that rocket will fly up. i need to determine a set of equations that will describe the THRUST of my rocket as a function of TIME or MASS or both. we can use M*(delta)v=dm*Ve and Vf-Vi=Ve*ln(Mi/Mf) and whatever other equations will help. Thrust= M(dv/dt) or Ve*(dM/dt).
Start with Newton's second law,
[tex]F = \frac{d}{dt} mv[/tex]
and keep in mind that mass is no longer constant, so you must apply the chain rule.
[tex]F = \frac{d}{dt}\left( mv\right) = v\frac{dm}{dt} + m\frac{dv}{dt}[/tex]
See what you can do from there.
--J
Wow, that does sound like a challenging lab! I can definitely understand why you need some help with determining the equations for thrust. Let's break it down step by step.
First, we need to understand what exactly we mean by thrust. In this case, we are looking at the force that propels the rocket upwards. From Newton's second law, we know that force is equal to mass times acceleration (F=ma). In this case, the mass of the rocket is changing as the water is being expelled, so we need to take that into account.
Next, we can use the equation you mentioned, M*(delta)v=dm*Ve, which relates the change in velocity (delta v) to the change in mass (delta m) and the exhaust velocity (Ve). This equation is derived from the conservation of momentum, where the momentum of the rocket (mass times velocity) must be equal to the momentum of the expelled water (mass times exhaust velocity).
We can also use the equation Vf-Vi=Ve*ln(Mi/Mf), which relates the final velocity (Vf) to the initial velocity (Vi) and the exhaust velocity (Ve), taking into account the change in mass (Mi/Mf).
Combining these two equations, we can come up with an expression for the thrust as a function of time and mass: Thrust = Ve*(dm/dt) = M*(dv/dt).
In simpler terms, this means that the thrust of your rocket is equal to the mass of the water being expelled per unit time multiplied by the exhaust velocity, or it can also be expressed as the mass of the rocket times the rate of change of its velocity.
I hope this helps and good luck with your lab! Remember to double check your equations and units to make sure everything is consistent.
  • · Replies 16 ·
9K
