Time travel by going fast in a spaceship: questions
The discussion revolves around the concept of time travel as described by special relativity, specifically focusing on the twin paradox and the implications of traveling at relativistic speeds. Participants explore the reasoning behind time dilation and the apparent discrepancies in time experienced by observers in different reference frames.
  • One participant questions the standard textbook explanation of time dilation, expressing confusion about why time appears to move slower in a spaceship compared to Earth when both perspectives seem valid.
  • Another participant explains that the perception of time being slower in one frame compared to another is due to the relativity of simultaneity, which depends on the observer's state of motion.
  • A reference to the twin paradox is made, noting that it is not a real paradox when the relativity of simultaneity is considered, especially when one twin accelerates to reunite with the other.
  • A participant mentions that despite reading about the twin paradox, textbooks often do not resolve the confusion surrounding it, leading to ongoing puzzlement among learners.
Participants express differing views on the interpretation of time dilation and simultaneity, indicating that multiple competing perspectives remain without a clear consensus on the resolution of the twin paradox.
Participants highlight the importance of understanding the relativity of simultaneity and the role of acceleration in the twin paradox, suggesting that these concepts are crucial for resolving the apparent contradictions in time dilation scenarios.
tufflax
Hi!
First of all, I just want to say that I don't know much about general relativity. But my question concerns an example often found in textbooks about special relativity.
On to my question. I have heard several times that one can travel forward in time (earth-time) by leaving earth, traveling close to c in a spaceship and then come back. But I don't understand this. I know the textbook reasoning behind it, but I'm not satisfied by the textbook explanations.
The textbook explanations go like this:
Say we have a mirror in the ceiling of the traveling spaceship, and send a light pulse straight up from the spaceship floor, let it reflect in the mirror, and come back. We measure the time of that, and call it t.
From earth, the light appears to travels not straight up, but in a longer path since the spaceship moves relative to earth. But since c is the same for all reference frames, the time it takes will appear longer from earth. Let's call it t2. So t2 > t.
And so time moves slower in the spaceship than on earth, so when the spaceship gets back, more time has elapsed on Earth than in the spaceship.
My question: What if the mirror experiment had been carried out on earth? Then the exact same reasoning could be made, and the conclusion would have been the opposite: that more time had elapsed in the spaceship than on earth. And without that particular explanation: Why would the time in one reference frame go faster than time in the other, given that the laws of physics are supposed to be the same in all inertial reference frames?
tufflax said:
Hi!
You can reverse the rolls - from the Earth's point of view, time is slow on the spaceship and normal on the Earth. From the spaceship point of view, time is slow on the Earth,and normal on the spaceship.
This is possible because the definition of "at the same time" depends on the observer and his state of motion.
If you draw a space-time diagram, it looks like the included figure below:
The stationary observer uses the green lines of simultaneity, the moving observer uses the red lines. Each concludes that the other clock is slow when they compare clocks using their own notions of simultaneity (the green and red lines on the diagram).
This is known as the twin "paradox". It's not a real paradox, of course, when the fact that simultaneity is relative is factored in. There's about two zillion posts on this, and just as much more written about it, if you care to read about it.
One interesting case is when one twin accelerates, so that they eventually re-unite. In that case, in flat space-time, the twin that accelerates wil be the younger when they reunite.
I figured this question would have been asked a lot, but didn't know the name of the paradox.
Anyway, I read up on wikipedia, and it makes more sense now. But the way they describe it in every textbook I ever read, they don't resolve the paradox. No wonder people are puzzled by it.
Thank you!
  • · Replies 65 ·
14K
  • · Replies 25 ·
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 36 ·
  • · Replies 31 ·
