Finding acceleration with Kinetic Friction coefficient
by phee
Tags: acceleration, coefficient, friction, kinetic
phee
phee is offline
#1
Aug18-11, 06:51 PM
P: 36
At a construction site, a small crane is raising two boxes of nails on a plank to the roof. One box has already been opened and is half full, while the other box is new. The boxes, including the nails, weigh 10kg (box 1) and 20kg (box 2), respectively and are both the same size.
If the coefficient of kinetic friction is 0.3, how fast will the boxes accelerate along the plank, once they start to slide?
This is for box 1:
m=10kg
Uk = 0.3
Weight = 10kg x 9.8 = 98 N
angle = 22
2. Relevant equations
Fnet = m/a
Fgx = mg(sin22)
3. The attempt at a solution
So so far I am trying to find the net force, so I concluded I needed to find Fgx
Fgx = mg(sin22) = 37 N
F(kinetic force) = -0.3(mg) = -29.4
I am not finished but was wondering if someone could at least hint to me as if I am going in the right direction. This has been confusing me for the past hour.
Phys.Org News Partner Science news on Phys.org
Internet co-creator Cerf debunks 'myth' that US runs it
Astronomical forensics uncover planetary disks in Hubble archive
Solar-powered two-seat Sunseeker airplane has progress report
PeterO
PeterO is offline
#2
Aug18-11, 06:58 PM
HW Helper
P: 2,316
Quote Quote by phee View Post
This is for box 1:
m=10kg
Uk = 0.3
angle = 22
Fnet = m/a
Fgx = mg(sin22)
Friction is miu * normal component of weight force.
EDIT: for the rest you are on your own as there is no detail of the set-up
alphali
alphali is offline
#3
Aug18-11, 09:06 PM
P: 24
Fnet=ma
F(force applied by the crane)-Fr(force of friction)+w(force of gravity on the box)=ma
projection along the direction of motion Wx=mgsin22 and Wx is in the opposite direction of motion so it will have negative value
F-(Uk.m.g)-(mgsin22)=ma
now i think ur missing the force applied by the crane in the givings because
a=(F-29.4-37)/10
so if u have the force applied by the crane u can calculate the acceleration
phee
phee is offline
#4
Aug18-11, 09:08 PM
P: 36
Quote Quote by alphali View Post
Fnet=ma
a=(F-29.4-37)/10
Would the crane have applied a force? It isn't given in any of the text. All that is happening is that the board that is being held by the crane is tilting on a 22 degree angle causing the boxes to slide
PeterO
PeterO is offline
#5
Aug18-11, 11:41 PM
HW Helper
P: 2,316
We need a picture !!! ?
You wondered if the crane would apply a force, because it wasn't given in the text.
You are one step ahead of us as we don't even have the text!!
EDIT: is the small crane lifting this all up at constant speed?
phee
phee is offline
#6
Aug22-11, 05:55 PM
P: 36
Quote Quote by PeterO View Post
It only says,
a small crane is raising two boxes of nails on a plank to the roof. I assume its at a constant velocity which means no acceleration from the crane.
The plank then tilts and the boxes begin to slide at a 22 degree angle.
Do I find Fgx then plug it into Fnet = m/a?
PeterO
PeterO is offline
#7
Aug22-11, 06:45 PM
HW Helper
P: 2,316
It only says,
With the plank at 22 degrees, you can find the component of the weight of a box parallel to, and perpendicular to, the plank.
The perpendicular component [the normal force] will enable you to calculate the Friction force acting.
Presumably the parallel component of weight exceeds this and you can then use F = ma to find the acceleration.
Don't forget that the half empty box has smaller forces involved, but at the last step, a smaller mass.
phee
phee is offline
#8
Aug22-11, 06:54 PM
P: 36
Let me spill what I have so far,
(for the 10kg box)
Fgx = mg(sin22)
Fgx = (10kg)(9.8 ms^2)(sin22)
Fgx = 37 N
Fn = Fgy
Fgy= mg(cos22)
Fgy= (10)(9.8)(cos22)
Fgy= 91 N
*Fn = 91 N*
Fkinetic friction = Ukmg
= (0.3)(10)(9.8)
=29.4 N
So...
Fnet = 91 N - 37 N - 29.4 N
Fnet = 24.6 N
Fnet=ma
a = 10 kg / 24.6 N
a = 0.4 m/s ^2
I hope I got it, I am not 100% sure I should be using Fgy in this equation though.
PeterO
PeterO is offline
#9
Aug22-11, 07:12 PM
HW Helper
P: 2,316
(for the 10kg box)
Fgx = mg(sin22)
Fgx = 37 N
Fn = Fgy
Fgy= mg(cos22)
Fgy= 91 N
*Fn = 91 N*
= (0.3)(10)(9.8)
=29.4 N
So...
Fnet = 24.6 N
Fnet=ma
a = 10 kg / 24.6 N
a = 0.4 m/s ^2
Fkinetic friction = Uk*Fn
= (0.3) * 91
= what ever you get.
Friction force is calculated from the NORMAL force, not the weight.
Then
Fnet = 37 N - (29.4 N)
I left your old 29.4 here - it should be the new value you calculate using the normal force.
The problem could be affected by the crane if the crane was accelerating the plank. In the absence of any indication otherwise, we can assume it is travelling at constant speed - the usual way cranes work
phee
phee is offline
#10
Aug22-11, 07:20 PM
P: 36
Fnet = Fgx - Fn
= 37 N - 27.3 N
= 9.7 N
Fnet = ma
9.7 N = (10kg)a
9.7 N /10kg = a
0.97 m/s ^2 = a
Therefore the acceleration of the 10 kg box is 0.97 m/s ^ 2
This is right? And thank you for the help kind sir
PeterO
PeterO is offline
#11
Aug22-11, 07:21 PM
HW Helper
P: 2,316
Fnet = Fgx - Fn
= 37 N - 27.3 N
= 9.7 N
Fnet = ma
9.7 N = (10kg)a
9.7 N /10kg = a
0.97 m/s ^2 = a
It all looks fine [hoping your sin and cos values were correct, I didn't check them but they look reasonable].
Register to reply
Related Discussions
Finding the Kinetic Friction Coefficient Introductory Physics Homework 0
Finding coefficient of kinetic friction Introductory Physics Homework 4
Finding the Coefficient of Kinetic Friction Introductory Physics Homework 1
Finding the coefficient of kinetic friction Introductory Physics Homework 2
Help finding coefficient of kinetic friction Introductory Physics Homework 6
