Submersible Water Pump, 4.3 amps, must work in the water,
  • Context: High School
  • Thread starter Thread starter Noble Metal
    Amps Pump Water Work
The discussion centers on the safety of using a submersible water pump rated at 220 volts and 4.3 amps while working in water. The pump, sourced from Italy, is equipped with grounding and an emergency electrical cut-off to mitigate risks associated with electrical shorts. Participants agree that if the pump is well-maintained and designed for submersion, the likelihood of electrical shock is minimal, especially when using rubberized tools. Overall, the consensus is that the pump's design and safety features significantly reduce the risk of electrical hazards.
  • Understanding of electrical grounding principles
  • Knowledge of submersible pump specifications
  • Familiarity with electrical safety standards
  • Basic knowledge of rubberized tool usage in wet environments
  • Research electrical grounding techniques for submersible pumps
  • Learn about safety standards for submersible electrical devices
  • Explore maintenance practices for submersible water pumps
  • Investigate the design features of high-quality submersible pumps
This discussion is beneficial for electricians, pool maintenance professionals, and anyone involved in the installation or maintenance of submersible water pumps, particularly those concerned with electrical safety in wet environments.
Noble Metal
Hi Friends, a high quality submersible water pump from Italy, it is 220 volt, 1,100SA, 4.3 amps, and it is grounded into the Earth while in use; and we also have an emergency electrical cut-off that cuts the power in case of an electrical short; but the question is, in a new high quality pump like this, how safe and how insane is it that I work in the water while the pump is running (No way to do the work unless the pump is running; and yes it is also again, grounded into the earth.) And again I’m so ignorant on this subject that I think as an example of ‘a submarine’, many many volts and amps, radio antennas and everything, under water in salt water; and so why is it in my little brain, Italy, USA, or Germany etc, cannot design and make a pump where when healthy and new is specifically designed that electronic leak, jump, or spark, is just basically impossible? – All honest true comments hoped for and needed; how safe am I to be in the water in work in this with rubberised tools; how likely is a shock likely, and if so, what are my chances wet, in this case with a one second shock at 4.3 amps?
If the pump is designed to be submersible, and is in decent repair, there shouldn't be any problem. A shock shouldn't be likely at all.
  • · Replies 39 ·
17K
