Static Equilibrium of a building
The discussion revolves around the static equilibrium of a planned 50-story building, focusing on the effects of wind force and the calculation of torque to determine the potential for the building to topple. The building's dimensions, mass, and the wind force acting on it are provided as context for the problem.
  • Participants discuss calculating the torques generated by both the weight of the building and the wind force about a pivot point. There is an emphasis on determining which torque is greater to assess the stability of the building.
Some participants have offered guidance on treating the building as a rectangle and using the center of mass for torque calculations. Multiple interpretations of the problem are being explored, particularly regarding the conditions for equilibrium and the implications of the wind force.
Participants are considering the assumption that the building is not anchored in bedrock, which may influence the analysis of its stability under wind forces. There is also a hint provided regarding the force exerted by the Earth on the building at the tipping point.
physicsss
A 50 story building is being planned. It is to be 200 m high with a base 56 m by 70 m. Its total mass will be about 1.8 X10^7 kg and its weight therefore about 1.8 108 N. Suppose a 200 km/h wind exerts a force of 1000 N/m2 over the 70 m wide face (Fig. 12-86). Calculate the torque about the potential pivot point, the rear edge of the building (where FE acts in Fig. 12-86), and determine whether the building will topple. Assume the total force of the wind acts at the midpoint of the building's face, and that the building is not anchored in bedrock. [Hint: FE in Fig. 12-86 represents the force that the Earth exerts on the building in the case where the building is just beginning to tip.]
http://www.webassign.net/giancoli5/9_73.gif
No one? =(
Calculate the torques from weight of building and wind force about the edge.
If the weight "wins", the building does not topple; if the torque from the wind force wins, the building topples.
Treat the building as what it is, a rectangle, the center of gravity or center of mass (assuming uniform gravitational field and uniform mass distribution) will be where the diagonals intersect, use the info given and apply the torque equilibrium condition.
13K
