How do ions conduct electricity in water?
  • Thread starter Thread starter scientifico
    Electricity Ions
The discussion centers on the mechanisms of electrical conduction in water, specifically focusing on how ions, such as those from dissolved NaCl, contribute to this process. Participants explore the roles of positive and negative ions, electron flow, and the reactions occurring at electrodes.
  • Some participants express confusion about how negative ions can contribute to electrical conduction, questioning whether they repel the flow of electricity.
  • Others suggest that negative ions transfer electrons to positive ions, completing the circuit from a potential loop perspective.
  • There is a discussion about the role of electrons in the flow of electricity, with some indicating that electrons flow along conductors inserted into the water.
  • One participant notes that reactions at the electrodes are necessary for charge transfer, specifically mentioning redox reactions.
  • Another participant explains that in a concentrated NaCl solution, Na+ and Cl- ions are attracted to the respective electrodes, with Na+ gaining electrons and Cl- losing electrons during the process.
  • A later reply introduces the concept of electron and hole migration in semiconductors as a related topic, along with a mention of galvanic corrosion and its dependence on ion flow in saltwater.
Participants express varying levels of understanding and agreement on the mechanisms of ion conduction and the role of electrons, indicating that multiple competing views remain. The discussion does not reach a consensus on the specifics of how electricity is conducted by ions in water.
Some participants highlight the complexity of the interactions between ions and electrons, as well as the specific conditions under which NaCl conducts electricity, such as being in an aqueous solution or molten state. There are references to the electrification series and the mass of ions affecting their behavior, but these points remain unresolved.
scientifico
Hello, in water NaCl break itself into positive and negative ions but i didn't understood how exactly works the electricity conductions... the negative ions go to positive so seen that they are negative shouldn't repel the flow of electricity causing no conduction?
thanks!
Chemistry news on Phys.org
I think
The negative ions go to the positive and give up electrons while at the same time the positive ions go to the negative and steal electrons. So from the point of view of the potential loop the circuit is completed.
but all is done only by ions, so where are the electrons of electric flow?
Any stream of charged particles means flowing current. After all
[tex]I = \frac Q t[/tex]
The electrons flow along the conductor that is inserted into the water to get closer to the positive ions, those electrons are fed to the conductor from the negative ions at the other end of the loop or from any other source like a wall outlet.
You mean like positive ions "charge" themself with the electrons of the flow ond "discharge" them at the positive point?
What happens at the electrodes is separate from the current flowing in the bulk of the solution. But you are right that some kind of reaction is needed on electrodes for the charge transfer - these are always redox reactions.
thanks!
I think that this thread doesn't belong here. It must be moved to chemistry section.
Anyways, coming back to the question. Hii Scientifico ! Always remember that salts conduct electricity when they are in aqueous solution or in fused/molten state. NaCl is dissociated in aqueous solution into Na+ and Cl- ions. Electricity is conducted by movement of ions , yes there is mass movement and loss of energy too unlike metallic conductors. Let us assume that cathode and anode both are made of Graphite. If we consider water as aqeous solution then H2O <---->H+ + OH-. Here Na+ and Cl- ions are attracted to respective electrodes rather than H+ and OH- because :
1. We are taking concentrated NaCl solution. Probability of NaCl ions to be attracted to electrodes is more than H2O ions.
2. After all Na+ has greater mass than Hydrogen so it repels H+ here and there. So is Cl- to OH-.
(Electrification series play negligible role)
Na+ is attracted towards cathode. It gains electrons from cathode(negative electrode) and become neutral Na and sticks to cathode. This way cathode looses electrons.
Cl- is attracted towards anode. It looses electrons to anode(positive electrode) and become neutral Cl and is released to atmosphere as Cl2. This way anode gains electrons and these electrons flow to positive terminal of battery. This is how electricity is conducted by ions.
As LostConjugate marks "So from the point of view of the potential loop the circuit is completed."
In a typical ionically charged liquid, negative ions flow in one direction, positive in the other. Some may combine, some don't.
You might find reading about electron( negative charge) and hole( positive charge) migration in semiconductors interesting...
another version of the same effects is galvanic corrosion:
http://en.wikipedia.org/wiki/Galvanic_corrosion
Cathodic protection [of underwater boat metals, for example, like through hull fittings and propellers and shafts] depends on the flow of ions in salt water...without such movement of charged particles there would be virtually no protection of boat metals.
  • · Replies 16 ·
