Finding the limit points
by natnat_nuts
Tags: advanced calculus, derived set, limit points, set
natnat_nuts
natnat_nuts is offline
#1
Aug20-11, 12:12 PM
P: 5
I am not sure if I should post it under Calculus and Analysis but since it is for my Advanced Calculus class the I decided to do it anyways.
If the metric space (S,d) is defined as S = R (set of real numbers) and d(x,y) = 0 if x=y and d(x,y) = 1 if x is not equal to y, find the limit points of A if A = Q (set of rational numbers). Based on my notes, the answer is Q but I don't seem to get it.
Note: a point x element of S is a limit point of A if every open ball B(x,r) for r>0 (that is, an open ball or open interval that has center x and radius r) contains a point y element of A other than x.
2. Relevant equations
3. The attempt at a solution
My answer is either {} null set or R. If I take a rational number x to be the center of an open interval, by property of real numbers, I can always find at least one rational number not equal to x that is within the open interval no matter how small or big the interval is. Therefore, all rational numbers are limit points and they are in the distance of 1 from each other provided that they are not equal. But following this logic also means that if the center is an irrational number say y, then I can always find a rational number within the open interval no matter how small or big the interval is. Therefore, R is the derived set or the set of limit points.
On the other hand, I am also thinking that if the distance is 1 if the numbers are not equal and 0 if they are equal mean that all Q are isolated points and therefore the set of limit points is null set.
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
micromass
micromass is offline
#2
Aug20-11, 12:51 PM
Mentor
micromass's Avatar
P: 16,545
Quote Quote by natnat_nuts View Post
This reasoning is based on that the open intervals are the balls of the metric. And this is true if the metric is d(x,y)=|x-y|.
But here, the balls are a lot smaller. For example: B(x,1/2)={x}, so the singletons are open sets. What does that mean for the limit points?
natnat_nuts
#3
Aug20-11, 08:59 PM
P: 5
does that mean that the set of limit points of A is {} null set since the singletons do not have other elements other than x?
micromass
#4
Aug20-11, 09:02 PM
Mentor
micromass's Avatar
P: 16,545
Yes, it would be the null set. All points in [itex]\mathbb{R}[/itex] are isolated points with that metric.
Register to reply
Related Discussions
Topology: Finding the set of limit points Calculus & Beyond Homework 15
Limit points and exterio points Quick quesiton Differential Geometry 2
Find all the limit points and interior points (basic topology) Calculus & Beyond Homework 2
Finding 4 points in a plane, when random points given Calculus & Beyond Homework 5
limit points Calculus & Beyond Homework 10
