1-D Kinematics Equations involving time & distance
The discussion revolves around a kinematics problem involving a flowerpot that moves vertically past a window. The pot is observed for a total time of 0.61 seconds while covering a height of 2.25 meters. Participants are trying to determine how high above the window the pot ascended before descending.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore various kinematic equations to relate distance, time, and velocity. There are attempts to calculate initial velocities and the time taken for the pot to reach the top of its trajectory. Questions arise regarding the validity of splitting the total time in half for ascent and descent, as well as the correct application of equations.
Several participants have provided guidance on using different kinematic equations and have pointed out potential errors in calculations. There is ongoing exploration of the relationship between initial and final velocities, as well as the effects of gravity on the pot's motion. Multiple interpretations of the problem are being discussed, with no clear consensus on the correct approach yet.
Participants note the importance of maintaining precision in calculations and the potential impact of rounding errors on the final answer. The discussion also highlights the need to clarify the use of signs in equations related to acceleration due to gravity.
razrsharp67
Hey, I've been working on this problem for quite a while now, and I can't seem to come up with the solution. I would love some help in the right direction.
Someone spots a flowerpot that sails first up and then down past an open window. The pot was in view for a total of 0.61 s, and the top-to-bottom height of the window is 2.25 m. How high above the window top did the flowerpot go?
ttotal= .61 s
Height = 2.25 m
Vf = Vi + axt
Xf = Xi + 1/2(Vi + Vf)t
To try and solve it, I figured that if the pot was in view for .61s total, it was .305s on each trip. So I figured its Vi = 2.25m/.305s = 7.377 m/s. So if its Vi=7.37, then it would take .7527 seconds to slow to 0m/s due to -9.8m/s2 for gravity. After .7527 seconds it would fly to 2.77m, making it .53 meters above the window. Unfortunately, this is not the correct answer. Any suggestions?
You calculated an average velocity that is neither vbot or vtop. Since you know a lot about x and t, why not use x = x0 + vx0t + axt2/2, (coordinate system: +x going up).
Plugging my knowns into that equation still comes out to be the same thing though.
X = 0 + (7.377 * .7527) + (-9.8 * (.7527 ^ 2) * .5)
X = 0 + (5.55) + (-2.776)
X = 2.776
2.776 - 2.25 = .53 meters, which is still wrong.
Is my problem coming from the fact that I can't actually split the .61s in half for each trip because they wouldn't be evenly distributed, making my initial velocity wrong? How do I fix that?
No, that's not your problem; The trajectory is symmetrical so it's split half and half as you've done.
Perhaps concentrate on finding the required velocities Vbot and Vtop to begin with. You know that on the way up the pot will have some "initial" velocity at the bottom (Vbot) and must traverse the span of the window (known) in a given time (known). What equation governs the distance with respect to time?
So, trying that:
2.25 = 0 + Vi * .305 + (.5 * -9.8 * (.305 ^ 2))
2.25 = .305Vi + (-.455)
2.70 = .305Vi
Vi = 8.87 m/s
t = -8.87 / -9.8 = .905 sec
Xf = 0 + 1/2 * (8.8 - 0) * .905 = 3.982 m
3.982m - 2.25m = 1.732 m
Which is still wrong. Ugh.
razrsharp67 said:
So, trying that:
2.70 = .305Vi
Vi = 8.87 m/s
Okay so far.
Whoa! What equation is that? Why not use [itex]d = v_o t - \frac{1}{2}g t^2[/itex]?
Alternatively, use energy conservation to find the height :wink:
So plugging into that one:
d = 8.8 * .905 - (.5 * -9.8 * (.905^2)) = 11.97 m
11.97 m - 2.25 m = 9.7m.
Which is still wrong. Thanks for the help Gneill, sorry I am so difficult.
The "-" sign in the equation was intended to make the acceleration negative. g is a positive constant (9.807 m/s2). The double negative has made the calculation invalid.
So instead, its:
7.964 - .5 * 9.8 * (.905^2) = 3.950
3.950 - 2.25 = 1.7 meters above the window?
razrsharp67 said:
So instead, its:
You seem surprised. Why don't you verify by checking the velocity of a pot dropped from that height when it reaches the bottom sill of the window? :smile:
1.7 still came back as incorrect :P
You may need to retain a few more decimal places in your intermediate results and supply another significant figure in your answer.
  • · Replies 16 ·
  • · Replies 34 ·
