Calculating Speed, Acceleration & Force on Take-off of 600kg Aeroplane
  • Thread starter Thread starter Turkish
The discussion revolves around a physics problem involving the take-off of a 600kg aeroplane, focusing on calculating its speed, acceleration, and the force required during take-off over a specified distance and time.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the order in which to solve the parts of the problem, with some suggesting starting with acceleration while others propose calculating speed first. There are references to relevant equations for average velocity and acceleration, and participants question the appropriateness of certain formulas.
The discussion is active, with participants offering different perspectives on how to approach the problem. Some guidance has been provided regarding the use of equations, but there is no explicit consensus on the best method to proceed.
There are reminders about the forum's guidelines against doing homework for others, emphasizing the expectation that students should engage with the material and attempt the problems independently before seeking help.
Turkish
Hi again.. Heres the question can someone give me a formula to solve these thanks.
An aeroplane of mass 600kg takes off from rest in 50secs over a distance of 1500m
a) calculate i) its speed when it lifts off
ii) its acceleration during take-off
iii) the force needed to produce this acceleration
Thanks in advance
You should solve part ii, first.
You know your initial velocity and position (both 0).
You know your final position.
You know your time.
You also know the mass of the plane (you need this to solve part iii).
While you don't have an equation that solves for acceleration, you do have an equation that solves for final position if you already knew acceleration. You can rearrange the equation to solve for acceleration.
Finding your acceleration gives you enough info to find your final velocity and the force required to accelerate the airplane.
Turkish, what do you think is the right formula ? Any guesses ?
Bob, I don't agree that one should solve part ii, first. I think it's ok to solve part i first, but I could be wrong, because it has been a few years since I've taken physics.
Average velocity (AV) when initial velocity (IV) = 0 is half final velocity (FV), and AV = (change in) x / (change in) t
If you want to solve ii first, use (change in) x = IV*t + .5*a*t^2 and then for i use FV = IV + a*t.
philosophking, 2 things :
1. We do not do other people's homework for them. That would be counterproductive, besides being unethical. We try to help by provoking thought or giving suggestions. We expect the student to have put in an effort before coming here. Please read the "sticky" at the top of this forum.
2. While I agree that your approach will work just as well as BobG's, I'd like to point out that you have a typo in your formula for the average velocity.
It's not too late to edit your post to conform to guidelines.
I think there should be no problem for diligent,bright students.
You are able to solve these questions.
  • · Replies 20 ·
