| New Reply |
Large rotating disk. |
Share Thread | Thread Tools |
| May18-12, 04:15 PM | #52 |
| May18-12, 04:25 PM | #53 |
| May18-12, 05:04 PM | #54 |
Mentor
This thread has been moving along fast. I haven't had time to reply. I'll post few replies now. I'll start with pervect and the hypersurface of simultaneity spirals.
Note by the way that while the spiral curves (like the blue line in the picture you linked to) can be thought of as simultaneity lines of component parts of the disk, other curves in the surface aren't simultaneity lines of the same observer. So the surface isn't really a surface of simultaneity. |
| May18-12, 05:10 PM | #55 |
Mentor
If there's a good argument for why the word "space" should refer to a congruence of timelike curves rather than a spacelike 3-dimensional hypersurface of spacetime, then I would have to say that "spacetime" was inappropriately named from the beginning. *) A frame field can be defined as a function that takes each member p of some subset of spacetime to a basis for the tangent space at p. |
| May18-12, 05:29 PM | #56 |
Mentor
I prefer to define terms (only) mathematically, and then explicitly state the rules that tell us how to interpret the mathematics as predictions about results of experiments. These correspondence rules are what turn a piece of mathematics into a theory of physics. No theory of physics is fully defined without a set of correspondence rules. Note that the same term can have different definitions in different theories of physics. For example, in classical electrodynamics, "light" is an electromagnetic wave. In QED, it's a state that involves photons. To deal with "what clocks measure", I would first define "proper time" as a coordinate-independent property of a curve given by an integral that I'm not going to write down here, and then I would state the correspondence rule that says that the difference between the numbers displayed by a clock at two events A and B, is the proper time of the curve that represents its motion from A to B. This correspondence rule is an essential part of the definitions of both SR and GR. I like this approach better because it makes it easy to understand that a) mathematics doesn't say anything about reality, b) a theory of physics consists of a purely mathematical part and a set of correspondence rules (that do say something about reality), and c) how the specific theory we're talking about is defined. |
| May19-12, 03:53 PM | #57 |
I would now like to propose a method to measure the geometry of the disc that is indisputably independent of simultaneity issues. We use a single clock that is fixed to a point on the rim of the rotating disc to make all measurements. First we measure the circumference of the disc by sending a signal all the way around the disc back to the single clock and then all the way back again in the opposite direction, using suitably placed mirrors, to obtain the radar circumference of the disc. Doing this we find the circumference is is gamma times longer than the circumference measured in the inertial reference frame at rest with the centre of the disc. Next we measure the radar radius of the disc, by sending a signal from the rim to a mirror at the centre and back out to the clock on the rim again. This time we obtain that the result that the radius of the disc is gamma times shorter than the radius measured in the non rotating inertial reference frame. The end result is that in the rotating reference frame, the ratio of the circumference to the radius is 2*pi*gamma^2. This method uses the same clock that is at rest in the rotating reference frame to measure both radar circumference and radius, so that the two measurements can be compared in a consistent way without any simultaneity issues or concerns about physical distortions of measuring rods due to "centrifugal forces". Interestingly, this alternative analysis obtains a different result from the usual interpretations, that the radius measured in the rotating frame is the same as the radius measured in the non rotating reference frame at rest with the spin axis of the disc. |
| May19-12, 04:02 PM | #58 |
Also, because the clock on the rim is moving, relative to an inertial observer's clock, the travel time it measures will be *smaller* than the travel time an inertial observer would measure. This will result in a *smaller* result for the radius of the disk for the moving observer, *not* the same result as the inertial observer. |
| May19-12, 07:13 PM | #59 |
Is there some reason to assume a different speed for the radial measurement?? As I read it, yuiop said exactly what you are stating here. The radial evaluation taken from the rim would be smaller than the measurement by an inertial observer. |
| May19-12, 08:42 PM | #60 |
http://en.wikipedia.org/wiki/Sagnac_effect Some people interpret this as the speed of light being different for light going with the rotation and light going opposite to the rotation. (I don't agree with this interpretation, btw.) There's also the more general point that the coordinate speed of light in non-inertial reference frames may not be c when evaluated over significant distances. See below. |
| May19-12, 08:47 PM | #61 |
| May19-12, 09:34 PM | #62 |
Recognitions:
As far as the conventionality of simultaneity goes, let me make one quick remark. I suspect that some 90% of the readers of the thread don't know any physics other than the high school version of Newton's laws. And if you are going to use Newton's laws (F=ma and all that), even in the low speed limit, following the Einstein clock synchronization convention is a "required option". I.e. it's optional whether or not you use it, you'll just get the wrong answers if you don't.
The errors may not be terribly large if your synchronization is "close" to Einstein's, but they'll be there. You'll see issues like two equal masses colliding at equal but oppositely directed velocities (as measured by your chosen synchronization scheme) not coming to rest. If you are using a formulation of physics that allows for generalized coordinates (for instance a Lagrangian formulation), these remarks do not directly apply - though as I recall it turns out to be a bit trickier than it looks to find the correct Lagrangian when you change your definition of simultaneity. I think a lot of readers mistakenly assume that simultaneity being "conventional" means that Newton's laws work with the different possible choices, and this isn't the case. |
| New Reply |
| Thread Tools | |
Similar Threads for: Large rotating disk.
| Rotating disk | Advanced Physics Homework | 1 | ||
| Rotating Disk | Introductory Physics Homework | 2 | ||
| Could a very large telescope see a star as a disk? | General Astronomy | 10 | ||
| Rotating Disk | Introductory Physics Homework | 6 | ||
| Rotating Disk | Special & General Relativity | 2 | ||
