Man hanging on a rope
by khuko
Tags: rope
khuko
khuko is offline
#1
Aug25-11, 01:29 PM
P: 7
Calculate the force that the man (weight 70 kg) should exert on the rope to stay in balance.
(answer = 137,2 N)
2. Relevant equations
Like I see, there are two ropes who are in equilibrium. In each rope the tension is the same but different from each other.
I suppose the sum of the tensions of both ropes are equally to the weight of the person
3. The attempt at a solution
The netforce is zero cause there's no movement or acceleration
Rope 1 = the rope who holds the chair.
Rope 2 = the rope the man holds.
in positive y-direction : T(rope1)-mg/2=0 (/2 because the weight from the two ropes are from the same person)
so T(rope1)=mg/2
the other one T(rope2)=mg/2
like you see my equations doesn't match the answer. I know that the rope 2 depends on rope 1 cause they are attached to each other. But i can't write that mathematical equation.
Can you help me?
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
Doc Al
Doc Al is offline
#2
Aug25-11, 01:33 PM
Mentor
Doc Al's Avatar
P: 40,905
How does the tension in rope 2 relate to the tension in rope 1? (Look at the middle pulley.)
khuko
khuko is offline
#3
Aug25-11, 01:44 PM
P: 7
If he pulls on rope 2 , then will the pulley follow and the chair go up. So it's related to each other or else the two ropes where indepented and the weight (and tension) where the same for each rope. ?
Doc Al
Doc Al is offline
#4
Aug25-11, 02:01 PM
Mentor
Doc Al's Avatar
P: 40,905
I'm looking for the mathematical relationship between the two tensions. Analyze the force on the middle pulley. (The net force on the pulley must be zero.) If the tension in rope 2 is "T", what's the tension in rope 1?
khuko
khuko is offline
#5
Aug25-11, 02:09 PM
P: 7
i must be -"T". So the equation for the rope 2 => T=mg/2
and for rope 1 => -T=-mg/2. (The opposite ). But a negative force doesn't exist :s
But i don't understand why the answer is 137,2 N. Cause my answer would be for rope 2 = 343,35
Doc Al
Doc Al is offline
#6
Aug25-11, 02:16 PM
Mentor
Doc Al's Avatar
P: 40,905
Quote Quote by khuko View Post
i must be -"T".
No. Analyze the forces on that middle pulley. How many rope segments pull up? What force do they exert? How many pull down? What's the downward force they exert?
Doc Al
Doc Al is offline
#7
Aug25-11, 02:36 PM
Mentor
Doc Al's Avatar
P: 40,905
Maybe it will be easier if you call the tension in rope 1 T1 and the tension in rope 2, T2. Then write a force equation for the middle pulley.
khuko
khuko is offline
#8
Aug25-11, 04:20 PM
P: 7
Allright. the middle pulley is the "center" point of all the tensions from the ropes.
everythings comes to this point (correct ?).
T1 is the tension in rope 1, T2 is the tension in rope 2
There's no force in the x-direction.
y-direction : The net force of the pulley must be zero cause there is no movement ([itex]\sum[/itex] Fy =0
T1 is coming to this pulley but also goes to rope 2 so we have two components of T1.
T2 is also coming to this pulley but also goes to rope 1 so we have positive T2 and a negative T2.
so : T1 + T1 + T2 - T2 - mg-mg = 0.
Am i close to it ?
Doc Al
Doc Al is offline
#9
Aug25-11, 04:29 PM
Mentor
Doc Al's Avatar
P: 40,905
Am i close to it ?
Analyzing the forces on the middle pulley is just a step in the solution, not the final answer.
There are two rope segments pulling upward: What force do they exert on the pulley?
There is one rope segment pulling down: What force does it exert on the pulley.
Note that we assume that the pulleys have no mass.
khuko
khuko is offline
#10
Aug25-11, 04:55 PM
P: 7
Hmm
The Two forces that are pulling the pulley upwards are T2. The first T2 goes to the ceiling and haves a normalforce called T2' who's going back to the rope 2 (and pulls the pulley upwards).
The force that pulls the pulley downwards is the normalforce of T1 called T1' .
We have also the mg from the first pulley who's pulling downwards.
so T2 + T2'-T1' -mg would be zero ?
Doc Al
Doc Al is offline
#11
Aug25-11, 05:05 PM
Mentor
Doc Al's Avatar
P: 40,905
You're making it a bit more complicated than necessary.
The ropes pulling upward have a tension of T2, thus the force they exert is 2*T2 upward.
The rope pulling down has a tension of T1, thus the force it exerts on the pulley is T1 downward.
Note that since the pulley is massless, there's no 'mg' term.
The net force must be zero, thus:
2*T2 - T1 = 0
Or:
2*T2 = T1
Now you have the relationship between T1 and T2. You'll need this in a bit.
Next step: Analyze the forces on the man+chair+bottom pulley (treat them as one 'object').
khuko
khuko is offline
#12
Aug25-11, 05:24 PM
P: 7
There are two forces that are pulling the pulley up, both are T1 and one goes down. That is the weight of the object (man+chair).
therefore the equation is
2*T1-mg
=>T1=mg/2
And if I substitute this in 2*T2=T1
We get for T2= mg/4
ow no. just saw that the bottom pulley haves two tensions going up with the same size of Tension 2 ( same object like the object on rope 2. Hmm, i'm confused :)
Doc Al
Doc Al is offline
#13
Aug25-11, 05:52 PM
Mentor
Doc Al's Avatar
P: 40,905
Don't forget about the rope that the man is holding--that also exerts an upward force.
khuko
khuko is offline
#14
Aug25-11, 06:08 PM
P: 7
Quote Quote by Doc Al View Post
Thanks, i now see that you must do mg/5 for the answer.
Thank you very much!.
How do i must learn to solve some exercises like this?
caus i don't understand the essential bout this exercise
Doc Al
Doc Al is offline
#15
Aug25-11, 06:23 PM
Mentor
Doc Al's Avatar
P: 40,905
You are welcome.
The only 'secret' is to try and solve as many problems as possible. Don't be afraid to just 'jump in' and try something. Whenever you solve a problem, try to analyze how you did it and see if you can generalize.
In this case, one 'trick' is to realize that the net force on a massless pulley is always zero (even if it accelerates)--that will give you at least one equation to use.
Register to reply
Related Discussions
Tension in a rope due to hanging mass Introductory Physics Homework 7
Box hanging from a rope, need to know the force. Introductory Physics Homework 3
A rope hanging over edge of table. Introductory Physics Homework 4
Tension in a hanging rope Introductory Physics Homework 3
Rope hanging from teh ceiling Introductory Physics Homework 1
