| New Reply |
My Antimatter Rocket |
Share Thread | Thread Tools |
| Aug27-11, 12:37 PM | #1 |
To put it short, I'm designing an antimatter rocket that a guy at NASA want's to see. I'm working hard but had a few questions for you guys:
1. What's the easiest way to get Positrons? 2. Any ideas on either storing it for a month or having a machine keep feeding the engine positrons like a portable accelerator or cyclotron or something? 3. When crashing into the water after the engine is ejected into orbit, does it matter that much if the rocket is aerodynamic on the way down or does it only matter when the rocket launches? Thanks for the help, -Lazer |
| Aug27-11, 01:10 PM | #2 |
I seem to remember reading recently that a small amount of anti-matter had been stored for 15 minutes and that was considered quite amazing.
| Aug27-11, 02:17 PM | #3 |
Admin
http://www-project.slac.stanford.edu...tronSource.htm http://www.positronannihilation.net/...on-Sources.pdf http://www.slac.stanford.edu/exp/e166/ POSITRON SOURCE OPTIONS FOR LINEAR COLLIDERS http://accelconf.web.cern.ch/AccelCo...S/TUZACH01.PDF Charged particles are generally not stored in cyclotrons, but rather storage rings, which store charge particles rather than increase the energy. It is unlikely to develop effective portable storage devices for positrons. Like a rocket motor will burn up in the atmoshpere. The main tank of the shuttle, as aerodynamic as it is, burns up in the atmosphere - usually over the Pacific Ocean. A positron anihilation reaction creates 0.511 MeV gamma-rays, and likely the energy density would be fairly low. That doesn't bode well for launching from the surface of the earth, where high thrust (and low Isp) are essentially required. |
| Aug27-11, 03:57 PM | #4 |
Obtain a large sodium-22 source (as per Astronuc) . It emits a lot of positrons (about 90% efficiency). Lifetime is about 2.6 years. See decay scheme in Fig 3.11 on page 8 of
http://mightylib.mit.edu/Course%20Ma...mechanisms.pdf 1 microamp of positrons requires about a 200 Curie source. You will need a license for anything above a few microCuries. This is not suitable for rocket propulsion, unless you can figure out how to accumulate the emitted positrons. Before you do anything else, use Newton's equations to calculate the rocket thrust. Also figure out how you might store 1 Coulomb (antiCoulomb?) of positrons. Bob S |
| New Reply |
| Thread Tools | |
Similar Threads for: My Antimatter Rocket
| Antimatter rocket v. black hole starship | Aerospace Engineering | 2 | ||
| If my rocket has two rocket engines going off each at an impulse at 20.00 N/S..... | General Physics | 3 | ||
| determine a rocket's altitude; how long rocket is in air | Introductory Physics Homework | 15 | ||
| The Multiple Launch Rocket System and Rocket Noises | General Physics | 1 | ||
| bolt falls off rocket, find rocket acceleration | Introductory Physics Homework | 3 | ||
