Measuring Microwave Owen Frequency with a Ruler and Marshmallows
  • Context: High School
  • Thread starter Thread starter sigma
The discussion revolves around measuring the frequency of a microwave oven using unconventional materials, specifically a ruler and marshmallows. Participants explore the methodology and implications of their experimental results, focusing on the relationship between wavelength, frequency, and the behavior of microwaves in the oven.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant reports measuring the microwave frequency as 2300 MHz, contrasting it with the labeled frequency of 2450 MHz, noting a 6% error.
  • Another participant explains that the experiment typically measures the distance between melted marshmallows, which corresponds to half the wavelength of the microwaves, and suggests using the wave equation to find frequency.
  • A participant mentions that the wavelength was nearly half the distance between the walls of the oven, which may have enhanced the clarity of the resulting wave pattern.
  • Observations of a "checkerboard pattern" in the heating of marshmallows lead to speculation about the interference of waves within the oven, with a request for clarification on the mechanism involved.
  • One participant notes prior exposure to the concept of wave interference in microwave ovens, indicating a shared interest in the topic.
  • Another participant expresses surprise at the precision of their measurements, suggesting luck may have played a role.
Participants express a range of views on the methodology and results, with no clear consensus on the accuracy of the measurements or the underlying physics of the observed patterns.
Participants rely on assumptions about the speed of light and the behavior of microwaves, with some steps in the reasoning process remaining unresolved.
This discussion may be of interest to those exploring experimental physics, wave phenomena, or unconventional measurement techniques in educational settings.
sigma
Hi! See if you can answer this:
Yesterday me and my friend measured the frequency of a microwave owen. Our experiment indicated 2300 MHz while the "right" answer, found on a sign on the back of the apparatus, showed 2450 Mhz. Our error hence: ~6%.
I find this pretty impressive, as I hope you do too, concidering the equipment we used:
a ruler and some marshmallows
The question is therefore:
How does one measure the frequenzy of a microwave owen using a ruler and marshmallows?
Let's see if someone can figure out how we did this!
Cheers
Usually this fun experiment is used to determine the speed of light using a micowave, marshmallows, and a ruler. But, if you assume the speed of light, you can measure the frequency.
What you actually measure is the distance between melted marshmallows, which is the distance between the anti-nodes of the microwaves, and thus is half the wavelength. Use the wave equation ([itex]c = \lambda \nu[/itex]) to find the frequency.
Good fun!
Aww. So soon. Okay you were right. Congrats!
We were lucky because the wavelength was almost precisly half the distance between the walls, I assume this made the resultant wave more articulated.
We also noticed that the marshmallows got hot in a sort of "checkboard pattern". This led us to the conclusion that a wave of identical wavelength must be traveling from the back of the owen, interfering with the perpendicular wave to form the pattern. As far as we know, there's just one whatever they're called (it's a sort of wide-beam electron cannon, right?) in the owen. Can someone explain this?
Someone actually brought this up a few days ago - I hadn't heard of it before.
Well I read about wave interference in microwave owens on a webpage and found the marshmallow thingo some place else. The precision of it was way better than expected, or perhaps we were just lucky?
  • · Replies 50 ·
  • · Replies 64 ·
  • · Replies 69 ·
