| New Reply |
Why is the kilogram the base unit of mass, instead of the gram? |
Share Thread | Thread Tools |
| Aug30-11, 01:45 PM | #18 |
Why is the kilogram the base unit of mass, instead of the gram?Just to defend Gauss: he was not just anyone, and he was a masterful experimentalist. The desirability of realizeable base units may have crossed his mind too. I wonder, isn't the definition of the meter, as the path travelled by light in 1⁄299 792 458 of a second (previously 1,650,763.73 wavelengths of krypton), suitable to define the millimeter and the centimeter as well? I am still wondering about the replacement of cgs by mks. I am not convinced that rigorous use of the definition of the meter and the kilogram was the motivation. |
| Aug30-11, 01:54 PM | #19 |
12 hours twice to make a day is maybe a bit more due to tradition, but it too has advantages over, say, 10 "standard hours" (shours? stours?) per day. (And, of course the use of base 60 in circular measurements has a long and glorious history. ) |
| Aug30-11, 01:58 PM | #20 |
| Aug30-11, 02:09 PM | #21 |
Originally the prefix range (milli up to myria) made one step per decade to facilitate a pronunciation similar to 11 pounds, 4 shillings and 6 pence |
| Aug30-11, 02:49 PM | #22 |
hi spareine! welcome to pf!
![]() but we would then have to be careful about how many zeros to put in the final answer … if we use 500 (cm) and 7000 (g), then the answer automatically comes out it dynes (or whatever), without our having to think about it
| Aug30-11, 04:07 PM | #23 |
Again, the units in the SI need to be practical; and a lot of it is driven by customer requirements, i.e. what the people who rely on accurate measurements actually need (be it in industry or academic research). |
| Aug31-11, 04:10 AM | #24 |
The cgs, which was adopted by the 1881 International Electrical Congress (IEC), contained three electrical quantities with a prototype: voltage, resistance and current. The coherent cgs-units were abvolt, abohm and abampere. The prototypes were called volt (a specification using a chemical cell), ohm (a thin, long column of mercury), and ampere (current which deposits silver by electrolysis at a certain rate). The cgs-units abvolt and abohm were unpractically small, 1 abvolt = 10-8 volt and 1 abohm = 10-9 ohm. Because of the large difference between these electrical base units and their prototypes, the cgs was unsatisfactory. Giorgi discovered that the prototype units were coherent in another unit system, mksA. Ampere's Force Law, which relates current to force, got a new coefficient in the mksA system (2·10-7 instead of 2). The mksA system was adopted some time later by the IEC. Fortuitously, in the new unit system, the base units for mass and length finally coincided with the prototypes from 1799 (kilogram and meter). Just lucky, not on purpose. |
| Sep8-11, 09:16 AM | #25 |
Recognitions:
For what its worth, there is a push to redefine the standard unit of mass in terms of fundamental quantities such as Plank's constant, Boltzmann constant etc.
Claude. |
| New Reply |
| Tags |
| cgs, kilogram, mass, si-system, unit |
| Thread Tools | |
Similar Threads for: Why is the kilogram the base unit of mass, instead of the gram?
| Atomic mass unit and Molar mass | Chemistry | 10 | ||
| Determine the base unit for the magnetic flux | Introductory Physics Homework | 5 | ||
| the Kilogram | General Physics | 8 | ||
| Standard Kilogram | General Physics | 18 | ||
| Grams and kilogram help?? | Introductory Physics Homework | 3 | ||
