Conventional Current: Tom's Questions Answered
  • Context: High School
  • Thread starter Thread starter ThomasR
    Current
Conventional current is defined as the flow of positive charge from the positive terminal to the negative terminal, which is opposite to the actual flow of electrons. In most contexts, "electric current" refers to conventional current unless specified otherwise. When determining the direction of the magnetic field around a current-carrying conductor, the right-hand rule confirms that if the electric current is considered conventional, the magnetic field direction is west for a north-to-south current flow. Additionally, in circuit diagrams, unless otherwise stated, the depicted current direction is assumed to be conventional current.
  • Understanding of electric current and charge flow
  • Familiarity with the right-hand rule for magnetic fields
  • Knowledge of electronic circuit components and their polarities
  • Basic concepts of conventional vs. real current flow
  • Study the right-hand rule in electromagnetism
  • Explore the differences between conventional current and electron flow
  • Learn about the implications of current direction in circuit design
  • Investigate the behavior of polarized components in electronic circuits
Students studying physics, electrical engineers, and anyone involved in electronics who needs clarity on current flow conventions and their applications in circuit design.
ThomasR
Just a couple of questions on conventional current that have been troubling me...
Firstly, does conventional current = electric current? I saw a question on a past exam that had "electric" current in a cable flowing from north to south, and asked to determine the direction of the magnetic field directly above the cable. The answer was west - so thus electric current == conventional current?
Secondly, if it is not stated on diagrams which show the direction of current, should it be assumed that it is depicting conventional current?
Thanks in advance
Tom
I'll try my best to these questions.
Electric current means the rate of flow of charge(in coulomb) passing through a given cross-section of a conductor. Conventionally, Its direction is taken to be positive to negative, opposite to the REAL direction of current but it is equal in magnitude to it. In most of the questions the word 'electric current' refers to conventional current, unless stated otherwise. In the question you asked, by applying right hand rule, the answer 'west' is only possible if the electric currect refers to conventional current. Thus, it confirms that here Electric currect does mean conventional current.
Lastly, Yes, if the question does not state otherwise, the direction of the flow of electic current shown in the diagram is the direction of conventional current.
Hope this helps. :smile:
Ab. S.
Up to you
In electronic circuit diagrams it does not matter which convention you use so long as you are aware of the polarity requirements of the components , that is you cannot connect polarised capacitors or transistors just any way you want. Conventional or real is just a mental state -- electrons flow from -ve to +ve and holes flow from +ve to -ve irrespective of how you visualize this
but you better connect the collector of an npn transistor to the +ve supply
and it's emitter to the -ve , otherwise it may still work but at 1/100th of it's capability.
Ray.
