New Reply
power supply to adapter
Share Thread Thread Tools
Aug31-11, 09:58 AM   #1
I'm trying to hook up my power supply to I/O Ethernet Adapter, and am getting confused with the wiring terminology.
The power supply is 24V DC (+/- terminals) and the Ethernet Adapter has NC, Chassis Ground, Common (C), and V (Supply).
I guess I am getting confused with what exactly Common and Chassis Ground are, and what I'm connecting the +/- to?
Thanks.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Aug31-11, 11:37 AM   #2
I would put minus on "Common" and plus on "Supply". You might connect "Chassis" to a water pipe or other earth-grounded thingie to provide a little noise and interference protection. Usually chassis and common are connected together someplace in a system and it is best to do that in only one place to avoid "ground loops", so that's probably why they are separate on your box.
Aug31-11, 02:56 PM   #3
What does it mean when it says that the DC supply will be connected to the internal power bus?
Sep1-11, 11:33 AM   #4
It probably means that the DC supply goes directly to the supply lines (buss) of the thing. I can't think of a way to say that any clearer, sorry...
New Reply
Thread Tools
Similar Threads for: power supply to adapter
Thread Forum Replies
small electric motor that can be plugged into a car power adapter Mechanical Engineering 6
replicating 2 dcell batteries with a power adapter Electrical Engineering 7
Power usage of LED light using AC adapter Electrical Engineering 1
Can a common 9V power supply be used as a -9V supply? Electrical Engineering 2
Dell recalls notebook power adapter cords Computing & Technology 0
