Solving Complex Equation arcsin(z)=w
The discussion revolves around solving the complex equation arcsin(z) = w, where z is expressed as a complex number. Participants explore the implications of this equation in the context of complex analysis, particularly focusing on the quadratic form derived from it and the multi-valued nature of complex functions.
  • One participant expresses curiosity about solving the equation and derives a quadratic form p² - 2*p*i*z - 1 = 0, where p = exp(i*w).
  • Another participant suggests using the quadratic formula to solve the equation and notes the importance of treating the square root and logarithm as multi-valued functions in complex analysis.
  • There is a discussion about the absence of a plus/minus sign in the solution, with one participant explaining that in complex analysis, the square root is understood to be multi-valued, making the plus/minus implicit.
  • Participants discuss the nature of complex roots, noting that the roots of z² = 1 can be seen as being π radians apart rather than simply negatives of one another.
  • Clarifications are made regarding the use of "log" in complex analysis, with emphasis on it referring to the natural logarithm (base e) and the confusion surrounding this notation.
  • One participant raises a question about the graphical representation of the complex square root, expressing uncertainty about the meaning of color graphs they have encountered.
  • Another participant provides Mathematica code to visualize the imaginary component of the complex square root function, suggesting that such tools are essential for technical fields.
Participants generally agree on the multi-valued nature of complex functions and the conventions used in complex analysis, but there are differing views on the notation and implications of the solutions presented. The discussion remains unresolved regarding the graphical interpretation of complex functions.
There are limitations in the discussion regarding the assumptions made about the multi-valued nature of functions and the notation used, which may lead to confusion among participants.
This discussion may be useful for individuals interested in complex analysis, particularly those exploring the properties of complex functions and their graphical representations.
Bassalisk
Hello,
I am trying to solve arcsin(z)=w. Where z is a complex number z=x+iy.
I got to this.
p2-2*p*i*z-1=0
where p= exp(i*w)
I don't know how to solve this quadratic equation.
This is not homework, I got this problem out of my head. I am curious.
Thank you.
You can solve that quadratic I bet. It's just:
[tex]p^2-2izp-1=0[/tex]
so using the quadratic formula for ap^2+bp+c=0:
[tex]p=\frac{-b+\sqrt{b^2-4ac}}{2a}[/tex]
now just substitute what a, b and c are. That is a=1, b=-2iz, and c=-1 right?
then let p=e^{iw}, take (multi) logs of both sides to get:
[tex]w=-i\log(iz+\sqrt{1-z^2})[/tex]
bet you can get that and note I didn't use plus minus since in the big leagues, that square root symbol really means the multi-valued square root function and the log symbol means the multi-valued log function but don't worry about that for now.
yup its clear, just correction "ln" instead of "log"(im meticulous). Again why not a minus sign too? I didn't understand why we don't include that
Ok, I can tell you exactly why. Cus' you're using z and w and not x and y. You're implying the complex-variable version of the inverse sine function and in Complex Analysis, the square root, log, and inverse trig functions are multi-valued and not just the single-valued real-version you use in high-school. It's ok to use plus, minus for the square root in that expression but then you know, that's baby-looking. Also, the log function in that expression is actually infinitely-valued. Best then to treat these functions as a single multivalued entity and deal with them appropriately. That is, when you actually use it to compute something, you're smart enough to realize the expression is multivalued and if necessary, manually extract the plus and minus version of the root object for each value of the log object. That is, the function is actually doubly infinitely valued, one set of infinite values for each root although the purist in here may object to calling it twice infinity.
But this gave me another puzzle. How does graph of complex square root look like?
I've seen some color graphs but i don't know what they mean.
But then again
consider equation
[itex]x^{2}-2x+2=0[/itex]
the solutions are:
[itex]x_{1}=1-i[/itex]
[itex]x_{2}=1+i[/itex]
This isn't one and the same complex number, how come we include +/- here then?
The reason is that jackmell is using the convention that in complex analysis, [itex]\sqrt{\dots}[/itex] is understood to be multi-valued, so the "plus/minus" sign is implict. Alternatively, because the two roots of [itex]z^{1/2}[/itex] need not be purely real, one prefers, I suppose, to think of the two roots as being [itex]\pi[/itex] radians apart in the complex plane rather than negatives of one another (even though it does amount to a minus sign difference), so the plus/minus isn't used.
Also, in complex analysis, only log base e is ever used, so the notation "log" refers only to the log base e. Even in ordinary math, "log" is typically understood to mean base e. The only time I really see "ln" when dealing with complex numbers is when one rights the complex logarithm in terms of its real and imaginary parts:
[tex]\log z = \ln |z| + i\mbox{arg}(z).[/tex]
but log z still has base "e" here? I found that confusing when i saw it in books.
Yes. The complex logarithm is always base e. For this reason, and because mathematicians tend to use "log(x)" to mean [itex]\log_e(x)[/itex] even when working only with real numbers, the complex logarithm is just written log(z), because there is no other base it could be.
Got Mathematica? Really, I think it's essential to get good with it if you're in a technical field. You know, why use a hand saw when you can just buy a skill saw? I mean really. Anyway, here's the code to generate a simple plot of the imaginary component of the complex square root function:
Code:
p1 = Plot3D[Im[Sqrt[x + I y]], {x, -1, 1}, {y, -1, 1}]
p2 = Plot3D[Im[-Sqrt[x + I y]], {x, -1, 1}, {y, -1, 1}]
Show[{p1, p2}, PlotRange -> All]
nothing fancy, we could do better. So that if you take [itex]\sqrt{z}[/itex] letting z=x+iy in the x-y coordinate plane, and put a point for each of the (double) value of the imaginary part of square root of x+iy, connect them all together and make surfaces, you get that plot.
Code:
I am fond of matlab. But even in MATLAB I am not that crafty. I will google something up. Thank you.
  • · Replies 27 ·
