Basic Vectors: If vector A and C are given what is the magnitude of vector B?
The discussion revolves around the calculation of the magnitude and angle of vector B, given vectors A and C in a vector addition context. The problem involves understanding vector components and their relationships in a two-dimensional plane.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to find vector B by rearranging the equation A + B = C and calculating the components of vectors A and C. They express confusion over a discrepancy in their computed magnitude for vector B.
Some participants provide corrections regarding the signs of the components and the interpretation of angles, suggesting that the original poster may have made an error in their calculations. There is ongoing clarification about the correct angle for vector C and its implications for the calculations.
Participants are discussing the implications of angles measured counterclockwise and the correct quadrant for vector C, which may affect the calculations of vector B. There is also mention of potential errors in the original poster's approach to determining the components of the vectors.
DavidAp
Vector A has a magnitude of 14.0m and is angled 38.0 degrees counterclockwise from the +x direction. Vector C has a magnitude of 13.2m and is angled at 22.4 degrees counterclockwise to the -x direction. If vector A + vector B = vector C what is (a) the magnitude (b) and angle - relative to +x direction - of vector B? State your angle as a positive number.
Answers:
(a) 26.9m
(b) 210 degrees
Relevant equations:
I will use vA as a shorthand to represent vector A and ||vA|| to represent the magnitude of vector A.
Ax = ||vA||cos(theta)
Ay = ||vA||sin(theta)
||vA|| = sqrt(Ax^2 + Ay^2)
My reasoning was that if I could find the vectors of vA and vC I could subtract vA from vC to obtain the vector vB.
vA + vB = vC
vB = vC - vA = <Cx-Ax, Cy-Ay> = <Bx, By>
From there I would use the equation for the magnitude of the vector to obtain the answer for part a.
||vB|| = sqrt(Bx^2 + By^2)
However, when I plug in the numbers I keep getting the incorrect answer, 23.5m.
Ax = 11.0m Ay = 8.62m vA = <11.0m, 8.62m>
Cx = -12.2m Cy = 5.03m vC = <-12.2m, 5.03m>
vB = <-12.2m-11.0m, 5.03m-8.62m> = <-23.2m, -3.59m>
||vB|| = sqrt((-23.2^2 + (-3.59)^2)) = sqrt(551.13) = 23.5m
I haven't attempted part (b) yet due to the fact that there is an error to the first part of the question. What did I do wrong? I felt fairly confident in what I was doing and have been stumped on this question for nearly an hour. Thank you in advance for reading my problem.
Cy=-5.03.
ehild
ehild said:
Cy=-5.03.
ehild
It gave me the right answer! Amazing! But, how did you get the negative? In my calculator sin(157.6) = 0.38. Multiply that by 13.2 and I got 5.03. Where did the negative come from?
The angle is not 180-22.4 but 180+22.4. It is counter clockwise to the -x direction, in the third quadrant.
ehild
11K
9K
