How Does a Decreasing Radius Affect the Speed of a Rotating Cylinder?
The discussion focuses on calculating the speed of the center of mass of a cylindrical roll of tissue paper as its radius decreases from 6.0 meters to 1.0 mm. The conservation of energy principle is applied, where the initial potential energy (mgh) is converted into rotational and translational kinetic energy. The moment of inertia for a solid cylinder is used, represented as (1/2)MR^2. The final formula derived for speed is v = sqrt(2gh * 10^6), incorporating gravitational acceleration (g = 9.8 m/s²).
  • Understanding of conservation of energy principles in physics
  • Familiarity with rotational dynamics and moment of inertia
  • Knowledge of kinematic equations and their applications
  • Basic calculus for manipulating equations
  • Study the conservation of energy in mechanical systems
  • Learn about the moment of inertia for various shapes
  • Explore the relationship between linear and angular velocity
  • Investigate real-world applications of rotational motion in engineering
Students in physics, mechanical engineers, and anyone interested in understanding the dynamics of rotating bodies and energy conservation principles.
gaborfk
Please, help with rotating rigid body problem
I am kind of stuck with this problem. Any takers?
A large, cylindrical roll of tissue paper of initial radius R lies on a long, horizontal surface with the outside end of the paper nailed to the surface. The roll is given a slight shove (V initial = 0) and commences to unroll. Assume the roll has a uniform density and that mechanical energy is conserved in the process. Determine the speed of the center of mass of the roll when its radius has diminished to r = 1.0 mm, assuming R = 6.0 meters.
This is what I got so far.
KE=(1/2)I(Omega)^2
for the cylinder I is :(1/2)MR^2
So mgh=(1/2)I(Omega)^2+(1/2)mv^2
I plugged in I
mgh=(1/2)(1/2)MR^2(Omega)^2+(1/2)mv^2
Then I used (omega)=v/r to get here
mgh=(1/4)MR^2(v/r)^2+(1/2)mv^2 the masses cancel
gh=(1/4)R^2(v/r)^2+(1/2)v^2
Now what? How do I get h? Thank you in advance!
To solve this problem, we need to use the conservation of energy principle, which states that the total energy in a system remains constant. In this case, the initial energy of the system is solely potential energy, given by mgh, where m is the mass of the roll, g is the acceleration due to gravity, and h is the height of the roll.
As the roll unrolls, the potential energy is converted into rotational kinetic energy and translational kinetic energy, given by (1/2)I(omega)^2 and (1/2)mv^2, respectively.
Since the roll is unrolling on a horizontal surface, there is no change in height (h) and thus no change in potential energy. This means that the initial potential energy is equal to the final kinetic energy, given by (1/2)I(omega)^2+(1/2)mv^2.
We can rewrite this equation as mgh = (1/2)I(omega)^2 + (1/2)mv^2, and since the mass cancels out, we can solve for v to find the speed of the center of mass of the roll when its radius has diminished to r = 1.0 mm.
v = sqrt((gh - (1/2)I(omega)^2) / (1/2)r^2)
To find the moment of inertia (I) of the roll, we can use the formula for a solid cylinder, given by (1/2)MR^2. Plugging this into the equation, we get:
v = sqrt((gh - (1/4)MR^2(omega)^2) / (1/2)r^2)
Now, we need to find the value of (omega) at r = 1.0 mm. Since (omega) = v/r, we can plug in v = 0 (since the roll is initially at rest) and r = 6.0 m (given in the problem).
This gives us (omega) = 0/6.0 = 0 rad/s.
Plugging this into the previous equation, we get:
v = sqrt((gh - 0) / (1/2)(0.001)^2)
Simplifying, we get:
Finally, we can plug in the given values of g = 9.8 m/s^2 and
  • · Replies 21 ·
  • · Replies 24 ·
  • · Replies 17 ·
18K
