Force on door from two hinges - easy - help anyone?
  • Thread starter Thread starter vtech
    Force Hinges
The discussion revolves around a torque and force problem involving a large door supported by two hinges. The door's dimensions and mass are specified, and participants are tasked with determining the forces acting on the door at each hinge in unit-vector notation.
  • Participants express confusion regarding the horizontal force component and its origin, questioning the necessity of the i-direction vector given the absence of horizontal movement. Others seek guidance on how to approach the calculation of the i-hat vector forces.
The discussion is active, with participants sharing their thoughts and seeking clarification on specific aspects of the problem. Some guidance has been provided regarding the use of free body diagrams and moments, but there is no explicit consensus on the approach to take.
Participants note that the vertical components of the forces at the hinges are understood to be half of the door's weight, but there is uncertainty about the horizontal forces and how to incorporate them into the calculations.
vtech
torque/force problem - two door hinges - help anyone?
A large door of height - 2.1 m - along y-axis that extends vertically upward and width - 0.95 m - along x-axis that extends outward from the hinged edge of the door. A hinge at 0.30 m from the top and a hinge at 0.30 m from the bottom, each support half the door's mass which is 28 kg.
(a) In unit-vector notation, what is the force on the door at the top hinge?
___ N i +____ N j
(b) In unit-vector notation, what is the force on the door at the bottom hinge? ___ N i +____ N j
I don't understand where the horizontal force - vector in i direction - is coming from if there's no horizontal movement and only gravity is acting along the y-axis or j hat
so my answers for the j hat vectors are simply 9.8x14= 137.2N which is the correct answer... but i don't understand parts A and C?
help anyone?
help please~!
anyone out there? i don't need to give me the answer... could anyone just point me in the right direction? how to find the i-hat vector forces in this problem?
thanksss a lot
Take the moment about the bottom hinge to find the answer for a) and then swap to the top hinge to find b)
i, too, am stuck on this problem, and what do you mean by take the moment? I am a bit rusty, and trying to remember that, but can't seem to remember... any help?
First you draw the free body diagram. Putting in all the forces into the diagram, there are altogether 5 forces, 2 at each hinge and the door's self weight. There are 2 unknown forces in the diagram since you have been told that the vertical component at each hinge is half of the door weight. 2 unknown forces and 3 equations derived from the diagram, it can be solved.
13K
21K
  • · Replies 31 ·
11K
  • · Replies 39 ·
