| New Reply |
TIME DILATION. WHY do clocks that are |
Share Thread | Thread Tools |
| Sep18-11, 03:11 PM | #205 |
[QUOTE=ghwellsjr;3508992 As I said earlier, no matter how much the train has accelerated, it still is just as far from c as before it started. SR makes no prediction that there is any condition in which time stops. Rather, it states that time will be completely normal for any train, it never slows down or speeds up or stops, no matter how it has accelerated in the past.[/QUOTE]
According to my starting FoR, which I didn't change, you are wrong. |
| Sep18-11, 05:35 PM | #206 |
| Sep18-11, 06:19 PM | #207 |
Well where do you draw the line, at which point do you decide where tidal(spagetiffication) forces and gravitational effects are distinct and apart. |
| Sep18-11, 06:25 PM | #208 |
How do accelerate a sample without making it move. |
| Sep18-11, 07:07 PM | #209 |
The acceleration goes as (v^2)/r. |
| Sep18-11, 07:52 PM | #210 |
Mentor
| Sep19-11, 04:55 AM | #211 |
But let me try to think through this out loud. The general form of the Lorentz Factor, γ = (1 - v2)-1/2, remains unchanged wrt acceleration. The value of the Lorentz Factor is directly affected only by the speed at which an oscillator is moving. So we can say that the period of an oscillator is directly affected only by the speed at which the oscillator is moving. The faster(slower) an oscillator is moving, the greater(lesser) its period, and the lesser(greater) its frequency. However, the speed at which an oscillator is moving is a direct effect of the oscillator's most recent acceleraton (assuming that the oscillator's speed hasn't remained constant throughout its entire history). That is, when the speed of an oscillator has changed during a certain interval, then we call the rate of change during that interval an acceleration. (Although an oscillator can presumably be accelerated, by changing its direction of motion, without in any way changing its speed, we're only concerned with the component of velocity that has to do with the oscillator's speed. And, a change in speed refers to, by definition, an acceleration.) I'm assuming that changes in either the rotational radius of the samples, or the RPMs of the samples isn't done on the fly. Otherwise, there are obvious accelerations involved. (Ie., if the arm is extended/retracted while keeping the RPMs constant, or if the RPMs are varied while keeping the rotational radius constant.) I agree that the experiments you mentioned do show that the general form of the Lorentz Factor is unaffected by acceleration. What I'm wondering about (with the understanding that the quantity of differential aging is a function of the time during which an oscillator is propagating at a certain speed), is when the change occurs wrt an oscillator whose frequency has been altered -- as it seems obvious that it can't be occuring while the oscillator is propagating at a constant speed. It follows that the changes in oscillator frequency must be occuring during intervals of acceleration. Which means that speed accelerations/decelerations do directly affect (produce changes in) the periods of oscillators. Thus, acceleration (involving variations in speed) affects time measurement. |
| Sep19-11, 05:32 AM | #212 |
Mentor
| Sep19-11, 12:52 PM | #213 |
Wrt differential time measurement, it's the accelerations that involve changes in speed that we're concerned with. But, again, a change in speed is, by definition, an acceleration. And time measurement depends on speed. Therefore it's incorrect to say that changes in the rate of time measurement don't depend on acceleration. It's just a semantic thing that needs clarification. By the way, thanks also for your feedback on my previous concern. Since I don't have a mechanistic theory of relativistic differential time measurement to refer to (the extant ether theories aren't quite what I had in mind), then I'm left with the geometric account. |
| Sep19-11, 01:06 PM | #214 |
Consider a traveling twin that doesn't just decelerate to a stop at the turn-around point and then accelerate back to the home twin but rather maintains a constant speed and makes a loop back to turn around. Now he has never changed speed but he has accelerated. Or consider Einstein's original introduction of the Twin Paradox in his 1905 paper in which one clock takes a circular path away from the inertial clock and every time it comes back, it has accumulated less time on it. |
| Sep19-11, 03:44 PM | #215 |
| Sep19-11, 05:04 PM | #216 |
Mentor
Do you know the difference between a partial derivative and a total derivative? When scientists say "X doesn't depend on Y" what they generally mean is [itex]\frac{\partial X}{\partial Y}=0[/itex]. Basically, this means that X does not change if you change Y without changing anything else. So if X is a function of Y and Z then the partial derivative of X wrt Y is obtained by keeping Z fixed. So, the type of centrifuge experiment described by Janus above is exactly the kind of experiment that would be used to investigate this type of dependence. That way you could change accelerations without changing speed and obtain [itex]\frac{\partial \gamma}{\partial a}=0[/itex] indicating that time dilation does not depend on acceleration, in the meaning intended by scientists. |
| New Reply |
| Thread Tools | |
Similar Threads for: TIME DILATION. WHY do clocks that are
| Question regarding light clocks and time dilation. | Special & General Relativity | 6 | ||
| Time Dilation or Mass Dilation | Special & General Relativity | 4 | ||
| I understand time dilation with light clocks, but... | Special & General Relativity | 15 | ||
| Gravitational time dilation vs velocity time dilation | Special & General Relativity | 22 | ||
| Question about calculating time dilation of clocks at sea level | Special & General Relativity | 12 | ||
