My CPU Usage Suddenly at 100% - What Do I Do?
  • Thread starter Thread starter Gokul43201
    cpu
The discussion revolves around a user experiencing 100% CPU usage on an old computer running Windows 2000, alongside issues with internet connectivity. Participants explore potential causes, particularly focusing on the possibility of viruses or trojans affecting system performance.
  • The original poster reports sudden high CPU usage and slow performance after startup, raising concerns about potential malware.
  • Some participants suggest checking the Task Manager for processes that may be consuming resources, with one noting a past experience where a virus was responsible.
  • Another participant recommends using Process Explorer for more detailed information about running processes and connections.
  • There is mention of a specific process, "avserve.exe," which is suggested as a potential indicator of a trojan, along with "server.exe." Participants discuss the difficulty in identifying suspicious processes.
  • The original poster confirms the presence of a detected infected file and notes that CPU usage normalizes in Safe Mode, but internet connectivity remains an issue.
  • Suggestions include using Google to research process names to determine their legitimacy.
Participants generally agree that the high CPU usage may be related to a virus or trojan, but there is no consensus on the specific cause or solution. Multiple competing views on how to diagnose and address the issue are presented.
Limitations include the original poster's uncertainty about identifying processes and the lack of detailed information about the detected infected file. The discussion does not resolve the relationship between CPU usage and internet connectivity issues.
Users experiencing similar issues with high CPU usage, potential malware infections, or difficulties with system performance and internet connectivity may find the discussion relevant.
Gokul43201
Staff Emeritus
Suddenly, my system performance indicator shows that my CPU usage is 100% - and this is just after start-up (ie : without starting any programs other than those processes that automatically open and reside in memory)
I only checked this because my computer (an old 750 MHz Dell Dimension, running Win 2K) seems to have slowed the hell down like crazy all of a sudden, and I was worried :frown:. I just ran Ad-aware to clear up data miners and other such programs...so I'm at a loss why this suddenly happened.
Also, I can't seem to connect to the internet anymore...is this related ?
HELP ! :cry: I'm a total computer ignoramus, so please be gentle.
Computer science news on Phys.org
If you do a control+alt+del and check your task manager, what processes are taking up the most memory? I had a similar problem recently, and I found a suspicious program eating up my resources. Turned out to be a virus. I don't know if that's what's going on with your machine, but I would certainly take a peek at the processes tab in Task Manager and see if anything looks fishy.
I agree with Math Is Hard.
You almost certainly have a virus.
Check the CPU usage in task manager, rather than memory.
Click the CPU column under the "process" tab to sort by usage
Only the "system idle process" should show any significant CPU usage.
Anything else is suspect.
I use Process Explorer from http://sysinternals.com/ instead of the windows taskmanger. You get more info that way.
You might want to take a look at it and see which "connections" are causing you problems.
Then perhaps you should Run the process called MsConfig, and go to the Autostart section; see which programs there might be viruses or programs of similar agenda and remove them so they do not start again. If you are not sure which the virus is, then post every entry on your list here and i can help you.
MiH, I did try that, but I'm not any good at telling if a name is "fishy"...so I really couldn't tell.
And yes, it does look like there's a trojan/virus running around, 'cause when I restarted this morning, my virus shield detected an infected file. Haven't had the time to look into it yet...will do that when I get home tonight.
Also, when I restart and log in under Safe Mode, my CPU usage is down to normal levels, but I still can't connect to the internet (I have a cable modem connection).
Thanks for advice all. Dilbert, I'll check out the Process Explorer tonight and perhaps post the entries tomorrow. The problem with all this is that I can't use the internet at my home computer anymore. Can this really be related ??
Or you can just get a screencap or two about the taskman window for the wizs to dwell.
hmm, i cannot really say.
Gokul, look in the MsConfig list, look for a "avserve.exe". If you have that entry then remove it from autostart.
or server.exe, that's usually what most trojans run under.
Just type the name of the process in Google for instance. you will find a lot of informations about it, and so you can see if it's a normal windows process or not ...
Good luck ! :)
Major
  • · Replies 30 ·
39K
  • · Replies 19 ·
10K
