Register to reply
Common balance
by krishna mohan
Tags: common balance
Share this thread:
krishna mohan
#1
Sep4-11, 02:25 AM
P: 118
Confused about a simple thing...
For a common balance, since both arms have equal weight, what causes the pole to choose a horizontal position?
Shouldnt it be stable in any other position as the torque around the centre is zero for any other position too?
Phys.Org News Partner Physics news on Phys.org
New complex oxides could advance memory devices
Nature's designs inspire research into new light-based technologies
UCI team is first to capture motion of single molecule in real time
Lobezno
#2
Sep4-11, 04:36 AM
P: 53
The arms of the balance move up and down, leaving the only position for equilibrium as exactly straight, for equal mass arms.
krishna mohan
#3
Sep5-11, 01:48 AM
P: 118
I am a little confused here....
Even if you move the balance to some other position, the potential energy is not going to change..as the increase in PE due to one mass moving up is compensated by the decrease due to the other moving down..
In a slightly tilted position, where does the restoring torque come from? The two masses seem to contribute equal and opposite torque leading to zero torque....
rude man
#4
Sep5-11, 05:22 AM
HW Helper
Thanks
PF Gold
rude man's Avatar
P: 4,914
Common balance
If the pointer points below the pivot point then if the scale is unbalanced the pointer provides a restoring torque = W*l*sina where W = weight of pointer, l = distance from pivot to pointer's c.g. and a = offset angle. Since scales are always balanced with known weights, the "open-loop" quantity da/dm is of no first-order importance. Scales are always used in a closed-loop manner.
I don't know much about scales but I would think that's how they're designed.
Register to reply
Related Discussions
Common collector vs Common drain amplifier Electrical Engineering 7
Common emitter vs. common collector power amplification Electrical Engineering 3
CCMRR Common to Common Mode Rejection Ratio Electrical Engineering 3
Mass balance/Charge balance Biology, Chemistry & Other Homework 2
Common static vs common electricity? General Physics 7
