How Do You Calculate Vertical Acceleration in a Block and Pulley System?
The discussion focuses on calculating vertical acceleration in a block and pulley system involving two blocks (m_1 and m_2) and two massless pulleys. The tension (T) in the string is derived as T = (m_2 * a_2) / 2, where a_2 is the horizontal acceleration of block m_2. The next step involves calculating the vertical acceleration (a_1) of block m_1 in terms of its mass (m_1), gravitational acceleration (g), and the previously calculated tension (T). The discussion highlights the importance of understanding the relationships between tension, mass, and acceleration in a frictionless system.
  • Understanding of Newton's laws of motion
  • Familiarity with concepts of tension in strings
  • Basic knowledge of gravitational acceleration (g)
  • Ability to manipulate algebraic expressions
  • Explore the derivation of vertical acceleration in pulley systems
  • Learn about the implications of frictionless surfaces in physics problems
  • Study the effects of varying mass on tension and acceleration
  • Investigate real-world applications of block and pulley systems in engineering
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in understanding the dynamics of block and pulley systems.
disruptors
appreciate if Sum1 can help
Two Blocks and Two Pulleys(Other answer didn't include T?)
A block of mass m_1 is attached to a massless, ideal string. This string wraps around a massless pulley and then wraps around a second pulley that is attached to a block of mass m_2 that is free to slide on a frictionless table. The string is firmly anchored to a wall and the whole system is frictionless.
Assuming that a_2 is the magnitude of the horizontal acceleration of the block of mass m_2, what is T , the tension in the string? Express the tension in terms of m_2 and a_2
I figured out the T to be (m_2*a_2)/2
but got stuck on the next question
Given T, the tension in the string, calculate a_1, the magnitude of the vertical acceleration of the block of mass . Express the acceleration magnitude a_1 in terms of m_1,g , and T.
I know there was a post like this, but the answer wasn't given in T...
Thanks a lot again...
(thanks cartoon for the last post)
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 68 ·
14K
  • · Replies 23 ·
  • · Replies 30 ·
  • · Replies 33 ·
11K
