| New Reply |
will weight of flying mosquito in a jar affect its weight ? |
Share Thread | Thread Tools |
| Sep4-11, 08:04 AM | #1 |
As a part of an experiment,..............
a scientist put 100 mosquitoes in a jar and shut it..... When he weighed the jar, while the mosquitoes were sleeping on the base of the jar, the weight came out to be 250 g........... Then, he shook the jar and the mosquitoes started flying inside it. He once again weighed the jar now and noted the reading....... What can be said about the reading – will be equal to 250 g or less than it or more than it? |
| Sep4-11, 08:25 AM | #2 |
Mentor
What do you think? Consider the center of mass of the system.
| Sep4-11, 10:12 PM | #3 |
Can someone explain it please?
| Sep4-11, 10:38 PM | #4 |
The jar would be a closed system when the mosquitos fly they apply an opposing force equal to the force needed to achieve flight therefore the jar will still read 250 g
| Sep4-11, 10:46 PM | #5 |
Recognitions:
As long as the center of mass of jar and mosquitos is not accelerating vertically, the total weight remains the same. Note that if the jar only contained air, then there would be a pressure differential within the jar, lower at the top, higher at the bottom, producing a net downwards force on the inside of the jar exactly equal to the weight of the air in the jar. As an example, filling a scuba tank with 80 cubic feet of highly compressed air will increase it's weight by 6 lbs, the weight of the 80 cubic feet of air at sea level and 1 atm pressure. When the mosuitoes are flying, or if a tiny balloon was hovering in the jar, the pressure differentital of the air is increased so that the net downwards force inside the jar exactly equals the total weight of the air and anything in the air, such as the mosquitoes and/or a hovering balloon, as long as there is no vertical component of acceleration of the overall center of mass.
| Sep5-11, 12:19 AM | #6 |
| Sep5-11, 12:49 AM | #7 |
| New Reply |
| Thread Tools | |
Similar Threads for: will weight of flying mosquito in a jar affect its weight ?
| Gravity's affect on weight in an elevator | Introductory Physics Homework | 1 | ||
| Weight of flying objects | Classical Physics | 3 | ||
| Weight of the flying bees | Classical Physics | 43 | ||
| Flying weight change | Brain Teasers | 5 | ||
| Birds flying in a plane, does the weight change? | General Physics | 14 | ||
