Does a proton hurts hitting me at 0.9999 c?
  • Context: Undergrad
  • Thread starter Thread starter Tachyon son
    Proton
The discussion centers around the potential effects of a proton, or electron, impacting a human body at speeds close to the speed of light (0.9999c). Participants explore the consequences of such an impact, including ionization effects and potential biological damage, while considering the physics of particle acceleration and interactions with matter.
  • Some participants suggest that a proton at high speed would not cause pain due to its low energy relative to pain thresholds.
  • It is proposed that the proton would lose energy through collisions with atoms in the body, potentially ionizing them and leaving a trail of ionization.
  • Concerns are raised about the possibility of DNA damage from ionization, which could lead to transcription errors and cancer, though the likelihood of significant harm from a single proton is debated.
  • One participant questions the certainty of the proton's interaction with the body, suggesting it might pass through without significant interaction due to its low charge and mass.
  • Another participant emphasizes the body's mechanisms for repairing DNA damage, arguing that cancer can only form if these mechanisms fail.
  • Mathematical calculations are presented regarding the momentum and energy of a proton at near-light speeds, comparing it to that of a bullet, suggesting potentially lethal consequences if a proton were to be stopped.
  • Clarifications are made regarding the speed of protons achieved by modern accelerators, with emphasis on the implications of relativistic effects on mass and energy calculations.
Participants express a range of views on the effects of a proton impact, with some agreeing on the low likelihood of immediate harm while others raise concerns about potential long-term biological effects. The discussion remains unresolved regarding the exact nature and severity of the consequences.
Participants note that calculations regarding momentum and energy are rough estimates and depend on specific conditions, such as the speed of the proton and the nature of interactions with body tissues. There is also mention of the typical operation of particle accelerators, which may not produce single protons.
Tachyon son
Sorry if the question is too stupid, but,
How about receiving an impact of a proton (or electron, with less mass) fired from a particle accelerator at just below c?
What will be the consecuencies in my body?
It won't cause pain, because it contains far too little energy to actually stimulate your pain receptors.
The proton will gradually lose energy by collisions with the atoms in your body. It will ionize those atoms, and leave a little streak of ionization behind it. (The same effect is exploited in bubble chambers, which allow physicists to see the tracks of particles.)
In most cases, the ionization won't really affect you at all. If the proton happens to ionize an important part of a cell, it will cause some damage. It probably wouldn't be enough damage to seriously harm the cell. If the proton happens to ionize some of the important atoms in a strand of DNA, it might eventually cause a transcription error, which, if unchecked, could result in a form of cancer.
In general, it takes thousands or millions of such particles slamming into your body to actually kill cells or cause enough DNA damage to lead to cancers. One proton really won't do much at all.
- Warren
True story
hmm, i don't think you can be too certain about these statements, though i am not saying they are wrong. For example it is quite possible that the proton will go directly through the body since there is far too little charge and mass present to trigger an actual interaction.
Ionize a part of a cell ?
The transcription error does not need to be unchecked. Basically it is multiplied when other cells are generated yielding some "false" biological entity that we call tumor. These tumors are only evil when they use blood of the human body. Via this process the cancer can spread out over the entire body and then you are f***ed...
regards
marlon
marlon,
I considered that maybe the proton would actually go right through you, but I figured the human body, being mostly water (and therefore mostly hydrogen) would react somewhat similarly to a bubble chamber. I didn't do the calculations to determine the mean free path or anything, but I could. :biggrin:
And the body has a bewildering variety of mechanisms to repair damaged DNA -- cancer can only form is all of those mechanisms fail.
- Warren
Hi chroot,...
i can only agree with your words here...
I just wanted to give some extra info on possible things that might happen...
Let's not talk too much about cancer because that can't be a good thing :biggrin:
regards
marlon
It's possible.
The momentum of the proton would be...
[tex]p=\frac{m_0v}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
Now, let's say that [itex]v=c \times (1-10^{-k})[/tex]<br /> then [tex]\sqrt{1-\frac{v^2}{c^2}} \approx \sqrt{2}10^{-k}[/tex]<br /> and<br /> [tex]p \approx \frac{m_0 v \times 10^{k}}{\sqrt{2}}[/tex]<br /> so<br /> [tex]p \approx 10^{k-19} \frac{kgm}{s}[/tex]<br /> (This is all of course, very rough).<br /> Now<br /> The mometum of a [tex]50g[/tex] bullet trave ling at [itex]2000 \frac{m}{s}[/itex]is<br /> roughly [tex]10^2 \frac{kgm}{s}[/tex]<br /> so if the proton is traveling at [tex]c \times (1 - 10^{23})[/tex] then it will have roughly the same amount of momenum as a bullet, and, if you manage to stop a proton traveling that fast, it will probably kill you because the amount of energy involved is pretty large... [itex]E \approx pc \approx 10^{10}J[/itex] or [tex]10^30 eV[/tex] (I think that's roughly a ton of TNT).[/itex]
NateTG:
That's enormously faster than the original poster's 0.9999c figure. :)
- Warren
I indicate 0.9999 c because, as far as I have read, is the speed achieved by a modern accelerator (i.e, tevatron).
I know that in that range a "bit" more speed near c increase massively the mass of the proton. I suppose it will be good to state a definitve speed in this topic to make the correct calculus. :wink:
If
[tex]v=(1-10^{-4})c[/tex]
then
[tex]p\approx 10^{-15} \frac{kgm}{s}[/tex]
and
[tex]E \approx 10^{-7} J[/tex]
Neither of which are particularly daunting numbers - certainly not enough to cook a human. Of course, as far as I am aware particle accelerators do not, typically, produce single accelerated protons. At 500kW beam power there's still enough heat to cause some serious problems.
  • · Replies 19 ·
  • · Replies 97 ·
11K
