How to Determine the Percent Mass of a Mystery Alkali Carbonate in a Reaction?
  • Thread starter Thread starter gaylateacher
    Mystery
The discussion centers on determining the percent mass of a mystery alkali carbonate through reactions with sulfuric acid. Participants suggest using titrimetric analysis with phenolphthalein and a standardized base to measure the carbonate percentage. Additionally, they recommend calculating the metal percentage from sample weight and considering weight loss from decarbonatation at high temperatures as an alternative method. Identifying the alkali metal is crucial for accurate results.
  • Understanding of titrimetric analysis and indicators like phenolphthalein.
  • Knowledge of chemical reactions involving alkali carbonates and sulfuric acid.
  • Familiarity with sample weight measurement techniques.
  • Basic principles of thermal decomposition in chemistry.
  • Research titrimetric methods for determining carbonate concentrations.
  • Learn about the thermal decomposition of alkali carbonates.
  • Study the properties and reactions of different alkali metals.
  • Explore standardized base preparation and usage in titrations.
Chemistry students, laboratory technicians, and educators seeking to understand quantitative analysis of alkali carbonates and their reactions.
gaylateacher
undefinedundefinedundefined
I have a mystery alkali carbonate. I need to react it with sulfuric acid. When this occurs I know the products are carbon dioxide, water, ions of the mystery metal in solution and ions of sulfate in the solution. My question is how do I find the percent mass of the carbonate in the reactant if I cannot capture and measure the volume of the carbon dioxide product? I know I need to identify the alkali metal but I do not know how? Any suggestions?
gaylateacher
Chemistry news on Phys.org
I think you are not doing the correct thing, first you don't know what metal you are using, and second, you are trying to find carbonate percentage in the sample. However, you may do it titrimetrically, by starting with phenolphthalein (and preferably, a known amount of standardized base added) and ceasing the titration whenever the purple color disappears; of course titration approach needs multiple tries to reach more precise results.
Then you may try calculating the metal percentage from the sample weight. This may give you an idea.
Could you not weight before and after reaction?
The difference should be the CO2.
You did not mention if your carbonate is pure.
Assuming it is, then it should be easy to identify the metal.
(assuming complete decomposition)
Another way I could imagine is without sulfuric acid, by putting the alkali carbonate in a oven at high temperature. Weight loss by decarbonatation should give you the result.
I am not a chemist, sorry if I am telling you stupid things.
13K
